Cold Air Intake
Externet (01-28-2024)
Cold air intake is a sort of universal misnomer for this style intake. Not actually colder, but they are less restrictive due to the smoother design causing less turbulence.
I have run lots of these and have found that I usually get the best results by replacing the intake tube, but tying back into the factory air box so the paper filter can be retained for better filtration and lesser likelyhood of oiling the MAF sensor which can happen with these come style filters. Actually, the D2 lays in such a way that you can use only two silicon couplers and that will allow you to connect as follows: Air box to silicon 45* coupler to MAF to 90* coupler to throttle body with no metal pipe.
This is a nice little rendition! Similar to one of the variations I posted up years ago, except you used an angled tube instead of an angled silicon coupler. I like it!
How is the MAF sensor retained in the tube? That would be my concern here, as if that is only a pressure fit it will surely come out of allow leakage around the connection causing unmetered air into the engine creating a lean condition.
Looks sharp!
Looks sharp!
Ultragauge has an air intake temperature reading, so I assume any decent OBDII scanner should be able to show it. Would definitely be interesting to see how different it is.
I would have assumed that a lot of turbulence in the intake stream would have been dealt with by the intake plenum.
Brandon318 (04-16-2022)
