Cold tick... Where to start
Old Apr 9, 2019 | 10:53 PM
Ben Matheson's Avatar
Default Cold tick... Where to start
Replaced exhaust gaskets but the next morning tick was back. Only ticks when cold and only for the first half mile.
Top 2 tests this week are running with belt off since I am replacing the alternator.
Banging on the cats when cold.
Ticks in time with rpm but I swear I heard it go out of sync a couple times.
Old Apr 10, 2019 | 08:20 AM
jdbayer's Avatar
It could be a slipped liner. I had the same thing. When I did my head gasket change I inspected the the sleeves and everything seemed fine. I switched over to full synthetic and added a bottle of ProLong and I installed a 180 degree thermostat. So far I haven't heard the tick at all.
Old Apr 10, 2019 | 08:27 AM
Red5's Avatar
Prob not a liner if it stops as it warms up. Liners usually behave just the opposite.
Where is it ticking? Have you poked around with a stethoscope? Which gaskets did you replace, head/manifold or manifold/Y-pipe, or both?
Old Apr 10, 2019 | 08:56 AM
My liners are pinned and it's worse when cold so doubt it's liners.
Only did the flange gaskets
Old Apr 10, 2019 | 09:40 AM
Red5's Avatar
In that case, have you checked the others? What you describe sounds just like an exhaust leak that I had. My gaskets tend to squish out over time.
If you change them, I've had better luck with the laminated metal type that cover a pair of ports. The single perf metal/composite type lasted only a few months for me.
Old Apr 10, 2019 | 10:31 AM
I agree I'm pretty sure it's exhaust. It was very quiet when I picked it up after having the gaskets done but then again it wasn't stone cold like first thing in the morning. I did use the smooth gaskets
Old Apr 10, 2019 | 11:06 AM
Jeff Blake's Avatar
Do you have SAI? try a stethoscope at those junctions. I usually use the stethoscope tube only for this, metal rod removed. Exhaust leak is also likely. Maybe try using copper spray-a-gasket next time
Old Apr 10, 2019 | 11:19 AM
CollieRover's Avatar
Slipped liner is probably the least likely reason. These ticks are hard to spot, because revving up drowns our the tick.
My old Purge Valve ticked. I have had exhaust ticks at the Manifold/Y pipe junction, but those got louder when warm.
Old Apr 10, 2019 | 01:26 PM
Richard Gallant's Avatar
I have to agree slipped liner is on the far end, a cold tick is lifters or exhaust. Both will quiet out once things warm up, exhaust manifolds leaks in particular get quiet after a few minutes of running. Lifters can tick with cold oil then quiet once things get warm,they should not but sometimes they do,it was more of a problem with the old single weight oils though.
Old Apr 10, 2019 | 02:07 PM
Externet's Avatar
Same on mine. Ticks only cold. No SAI. Fades away when hot. Will keep an eye on this thread for diagnostic successes... Until then, will find what was it when something finally explodes.
