Cold tick... Where to start
Old Apr 10, 2019 | 02:37 PM
Dave03S's Avatar
I’ve had a cold tick caused by a small vacuum leak... check the nipple on the back of the throttle body where the hose from the valve cover goes.
Old Apr 10, 2019 | 08:08 PM
Extinct's Avatar
Exhaust gaskets easy fix, take them out, coat both sides with red silicone and allow to skin, put them back in and barely snug down bolts, let cure 24 hrs before tightening.
Old Apr 10, 2019 | 10:12 PM
Ben Matheson's Avatar
Manifold or y pipe?
Old Apr 11, 2019 | 12:57 AM
Richard Gallant's Avatar
Manifold Ben, the Y pipe if torqued down correctly should not leak. Exhaust manifolds on everything start to leak as the gaskets wear and stuff gets loose
Old Apr 11, 2019 | 08:43 AM
NewToTheTwo's Avatar
What oil and weight are you running?
Old Apr 11, 2019 | 10:17 AM
Extinct's Avatar
Originally Posted by Ben Matheson
Manifold or y pipe?
Both. It might still tick, but it won't be an exhaust leak. This technique also preserves exhaust gaskets inperpetuity. I have never had an exhaust gasket blow out using this technique. The silicone shields the gasket, and the gasket provides the silicone enough substructure to resist blowout.
Jason428sc
Apr 23, 2020 09:03 AM
kfs90
Nov 26, 2017 04:11 PM
Sixpack577
Jul 18, 2017 08:20 AM
LR03NJ
Dec 7, 2016 07:12 AM
Disco Fuego
Apr 21, 2012 11:17 AM
