Collapsed radiator hose
Old Apr 19, 2020 | 06:01 PM
Titans34187's Avatar
7th Gear
Default Collapsed radiator hose
I own a 2002 Land Rover Discovery Series II. In the morning before starting vehicle, I noticed my upper radiator hose is collapsed/ a vacuum has occurred. I opened the coolant reservoir cap and the vacuum was released. What causes this?
Old Apr 19, 2020 | 07:16 PM
The Deputy's Avatar
Replace coolant reservior cap, or run it partially cracked open just a bit...until you get one...and see if that makes a difference.
Brian.
Old Apr 19, 2020 | 07:49 PM
7th Gear
Deputy,
Thanks for the advice! I ordered a new cap, it arrives tomorrow. lol keep you posted.
New question- my oil light flickers on and off at idle. What are your thoughts? Thanks!
Old Apr 19, 2020 | 08:01 PM
Best4x4's Avatar
Sensor, oil pump, or bearings for the oil light. Does it flicker at idle upon a cold start or once it gets warmed up?
Old Apr 19, 2020 | 08:04 PM
7th Gear
Default Oil pump
I only noticed it after I had been driving and came to a stop and was idling
Old Apr 19, 2020 | 11:44 PM
User's Avatar
what weight oil?
Old Apr 20, 2020 | 04:31 AM
The Deputy's Avatar
Besides what's already been mentioned, do you have a device to monitor engine temps? Not a bad idea to have one, since higher than normally engine temps can really thin the oil out. The gauge in the cluster is useless, for exact temp monitoring.
Brian.
Old Apr 20, 2020 | 05:28 PM
7th Gear
Default Oil light
I had the oil light issue evaluated. Oil pressure was good, sensor is functioning properly. However, I did change the oil to 5w 30- too thin. I’m switching to 15w 40.
Titans34187
Apr 20, 2020 06:35 PM
Vicky Ka
Dec 15, 2018 03:00 AM
Lisa Bunch
Off Topic
Dec 1, 2017 02:22 PM
