Colour coded headlamps D2
Old Apr 11, 2020 | 11:01 AM
Nosugar0carbs's Avatar
Default Colour coded headlamps D2
So I had some free time to change something up. I decided to take the plunge, I had 2 options based on the time I had. Either separate the housing and paint only or paint and retrofit projector beams. I didn’t have enough time for the projectors so only painting was done, another day projectors. Here is the final finish and assembled, the closest colour I could get(which is close to Zambezi silver) was aluminum. Took approx 3 hours from start to finish with the heat gun method, would have been faster with the oven methed.
Old Apr 11, 2020 | 04:04 PM
No Doubt's Avatar
Nice look!
Old Apr 11, 2020 | 06:23 PM
Originally Posted by No Doubt
Nice look!
Thank you Nodoubt.
Old Apr 11, 2020 | 07:28 PM
User's Avatar
Okay, how did you get the headlight apart?
I'm doing this. Today.
Love the look
Old Apr 11, 2020 | 07:38 PM
Love the look
A heat gun in low heat on the back side of the housing and 2 panel removal tools, or wide flat blades, work your way around the housing slowly.
Old Apr 11, 2020 | 11:04 PM
Jwehking's Avatar
How did you reseal?
Old Apr 11, 2020 | 11:32 PM
Originally Posted by Jwehking
How did you reseal?
Reheated the housing and pressed back into place, then went around the border and clip points with a thin bead of black rtv.
Fastercat
Mar 29, 2020 02:09 PM
loanrangie
May 17, 2016 04:36 AM
jmeyers278
Jan 3, 2013 08:54 PM
Street Wolf
Appearance & Camping Set Ups
Oct 9, 2009 11:57 PM
CandiMan
Tires
Aug 18, 2008 04:28 PM
