Common sizes that will cover 90 to 95% of trail fixes
I am re-consolidating my trail toolkit and decided to check what ChatGPT says about common sizes that will cover 90 to 95% of trail fixes. I thought it would be used to share in the forum.
For a Land Rover Discovery 2 (1999–2004), you'll find that most fasteners are metric, although a few imperial-sized wrench/socket heads occasionally appear on driveline and supplier-sourced components. Owners and technicians generally consider the D2 to be about 90% metric.
Most Common Socket & Wrench Sizes
If you're working on a Discovery 2, these are the sizes you'll use most often:
- Socket/Wrench Common Fastener
- 8 mm Hose clamps, trim brackets
- 10 mm M6 bolts, interior trim, engine accessories
- 13 mm M8 bolts, body brackets, engine bay components
- 15 mm Suspension and chassis hardware
- 17 mm M10 bolts, steering and suspension
- 19 mm M12 bolts, suspension, driveline
- 24 mm Axle, suspension, hub-related fasteners
- 27 mm Differential and axle work
- 30 mm Hub and driveline work
The most common metric thread sizes on the vehicle are M6, M8, M10, and M12. Typical hex-head sizes are: M6 = 10 mm, M8 = 13 mm, M10 = 17 mm, M12 = 19 mm.
Torx & E-Torx Sizes You'll Need
Land Rover loves Torx fasteners. A Discovery 2 tool kit should include:
- T20
- T25
- T30
- T40
- T45
- T50
- T55
And External Torx (E-Torx):
- E8
- E10
- E12
- E14
These are commonly found on:
- Seat mounts
- Engine accessories
- Transmission components
- ABS and braking hardware
- Steering column components
- Discovery 2 "Must-Have" Socket Set
For routine maintenance on your Discovery 2, I recommend:
Metric Sockets
- 8 mm
- 10 mm
- 13 mm
- 15 mm
- 17 mm
- 19 mm
- 24 mm
- 27 mm
- 30 mm
Torx
- T20–T55 set
E-Torx
- E8–E14 set
Other
- ½-inch breaker bar
- Torque wrench
- 36 mm fan clutch wrench (for many V8 cooling system jobs)
- 9/16-inch and 5/8-inch wrenches (occasionally useful on aftermarket or supplier-sourced components)
ü Fasteners You'll Encounter Most Often by Job
Jobs and Common Sizes
- Oil change 27 mm drain plug (some aftermarket plugs vary)
- Serpentine belt 15 mm tensioner
- Brake calipers 13 mm, 15 mm
- Driveshafts 9/16", 14 mm, 15 mm depending on shaft
- Suspension 18 mm, 19 mm, 24 mm
- Wheel nuts 27 mm
- Alternator 13 mm, 15 mm
- Water pump 10 mm, 13 mm
- Interior trim T20, T25, T30
For your 2003 Discovery 2, if you're putting together a trail or garage toolkit, a compact set containing 8, 10, 13, 15, 17, 19, 24, and 27 mm sockets plus T20–T55 and E8–E14 Torx sockets will handle roughly 90–95% of repairs you'll encounter on the vehicle.
- T20
- T25
- T30
- T40
- T45
- T50
- T55
- E8
- E10
- E12
- E14
- Seat mounts
Metric Sockets
- 8 mm
- 10 mm
- 13 mm
- 15 mm
- 17 mm
- 19 mm
- 24 mm
- 27 mm
- 30 mm
Torx
- T20–T55 set
E-Torx
- E8–E14 set
Other
- Torque wrench
- Wheel nuts 27 mm
