Competency required to change head gaskets?
Unless you got the time on your hands, $700 for labor is not bad. With parts and everything you are looking at at least $1100 I would think. I'm on break until I have to teach a class next month so I figured I might as well do it and learn about my truck at the same time.
I'm in Northeast PA. Labor rates here are definitely not as high as NY or NJ. I think he's $50-60 per hour but I'm really not sure.
I am supplying mech. with gaskets and bolts, new polyvee belt and 6 Qts. Royal Purple 10w40... which he's fine with. let us know what you plan to do, if you are going to do the work yourself or if you need a Mechanic to do this, in which case i can suggest someone competent for you in VT....
collin Barrows
08-28-2011 07:13 AM
RROJ
03-26-2011 02:37 PM
