Competency required to change head gaskets?
Old Jun 25, 2009 | 12:01 PM
JBEGIN's Avatar
yes thats just to machine the heads... which im glad to pay because im still under the "going rate" for a HG job, $1400 total... do you live in the northeast by any chance?
In vermont the labor rate is about half of what NY mechanics go for....
Old Jun 25, 2009 | 12:03 PM
lipadj46's Avatar
Unless you got the time on your hands, $700 for labor is not bad. With parts and everything you are looking at at least $1100 I would think. I'm on break until I have to teach a class next month so I figured I might as well do it and learn about my truck at the same time.
Old Jun 25, 2009 | 12:06 PM
JBEGIN's Avatar
Not to mention, saving you a lot of money...
Old Jun 25, 2009 | 12:13 PM
i_m_jon's Avatar
I'm in Northeast PA. Labor rates here are definitely not as high as NY or NJ. I think he's $50-60 per hour but I'm really not sure.
Old Jun 25, 2009 | 12:32 PM
JBEGIN's Avatar
I am supplying mech. with gaskets and bolts, new polyvee belt and 6 Qts. Royal Purple 10w40... which he's fine with. let us know what you plan to do, if you are going to do the work yourself or if you need a Mechanic to do this, in which case i can suggest someone competent for you in VT....
Old Jun 25, 2009 | 01:40 PM
i_m_jon's Avatar
I think I have enough information. I'm going to order the gaskets and bolts and move forward with my local mechanic. I am amazed at how quickly you can get advice on this forum; thanks to all.
Old Jun 25, 2009 | 01:56 PM
JBEGIN's Avatar
also might be a good idea for you to supply your mechanic with a copy of the RAVE cd so that he has the torque specs when he puts everything back together, and any other info. he may need
steveo2000
Dec 20, 2012 12:54 PM
collin Barrows
Aug 28, 2011 07:13 AM
RROJ
Mar 26, 2011 02:37 PM
nashville rookie
Mar 5, 2009 09:48 AM
malmberg
Feb 12, 2009 07:30 PM
