At a complete loss with different codes. Need HELP :)
So these are my current issues. I love my discovery, but these codes are driving me insane. I've been working on these awhile. Here's what I've done:
New Bosch O2 sensors New MAF New Bosch Platinum Plugs Bought new oil separator but haven't installed it yet. When I bought it the CAT's had already been cut out. I put a plug fouler on bank 2 sensor 2 but maybe I need something taller, that takes the O2 out of the stream more. Any help appreciated. https://cimg2.ibsrv.net/gimg/landrov...1d65ddb9b9.jpg https://cimg2.ibsrv.net/gimg/landrov...3ea4bbbc61.jpg https://cimg3.ibsrv.net/gimg/landrov...845a500f3a.jpg |
Do you still have old MAF? if yes, put it back and clear the codes. If same codes come back, we can rule out MAF |
Originally Posted by Friday Night Disco
(Post 670153)
Record your 02 sensor voltages, bank 1 and 2, sensor 1. Post up here or on youtube video preferably. Fully warmed up, idling.
Originally Posted by rcdoeshair
(Post 670155)
I do still have the old one. I will swap them tomorrow .Thanks for the help.
(Post 670155)
Originally Posted by Extinct
(Post 670162)
https://cimg8.ibsrv.net/gimg/landrov...6b79c82b9c.jpg Also, I noticed that my fuel trims were weird. Like I said, I don't have cats's so my rear fuel trims was 0%. But my front bank 2 stayed at 25% and my bank 1 was bouncing between 25% and -100.8% . https://cimg2.ibsrv.net/gimg/landrov...ccb72837d7.jpg https://cimg4.ibsrv.net/gimg/landrov...7d324e245b.jpg |
We need to see a graph of your oxygen sensor voltages, you need to use the graph function instead of the display function. Record a video and put it on youtube with a link to the video. Your oxygen sensor voltages should be cycling between 1 volt and zero volts - the display that you posted shows only .1 volts. If it only ever reads that you likely have bad oxygen sensors - they read close to zero when they go bad. the sensor shoudl read 1 volt on cold startup, then start cycling after a few minutes. zero volts or .1 volts indicates a full lean condition, that would cause your fuel trims to go full rich.
Did any of the codes come back?
(Post 670441)
As far as codes coming back, I only drove it a couple of miles as I live out in the middle of nowhere. I just drove up to the hunting cabin and back, so maybe 2 or 3 miles total. Not sure if this changes anything but the part that's circled, (this is a Google pic as it's dark here, but mine is not connected to anything. I believe it's supposed to go to the SAI canister?? I found the hard plastic line that comes from the canister and I believe is supposed to hook up to this valve, but it wasn't connected to anything .when I hooked it up to this valve, the engine ran like ****! The idle speed was low . As it sits right now, I'm getting about 8mpg (yay me). Before I changed the plugs I was getting about 13. |
my guess is the low fuel economy is because both oxygen sensors are dead and thereby reading full lean, causing that ECU to go full Rich to try and compensate.
