Originally Posted by rcdoeshair
(Post 670446)
Not sure if this changes anything but the part that's circled, (this is a Google pic as it's dark here, but mine is not connected to anything. I believe it's supposed to go to the SAI canister?? I found the hard plastic line that comes from the canister and I believe is supposed to hook up to this valve, but it wasn't connected to anything .when I hooked it up to this valve, the engine ran like ****! The idle speed was low .
Originally Posted by mollusc
(Post 670480)
What pic are you referring to? I don't see anything in this thread that is circled. The only images are your sensor screenshots.
Sorry. For some reason it didn't upload. Let's see if this works. |
Yes, that line is one of the ones that is supposed to go to the SAI unit. I don't remember which end of the unit it goes to.
On my older truck that doesn't have SAI, that port is simply capped. |
(Post 670492)
I would be surprised if it ran worse with the hose connected, since with it unconnected you've basically got a massive vacuum leak in your intake.
Originally Posted by Friday Night Disco
(Post 670445)
Did any of the codes come back?
https://cimg4.ibsrv.net/gimg/landrov...835fe3e425.jpg Here are the logged codes https://cimg6.ibsrv.net/gimg/landrov...43b1430836.jpg Here are the 2 pending codes |
(Post 670501)
I had some of the same issues. Misfires, leak detection pump, rough idle, smell, o2 sensors, maf, etc. turned out to be a bad purge valve. Got a Hyundai 911-800, replaced it for $21 and all went away and never returned. |
Originally Posted by Extinct
(Post 670441)
We need to see a graph of your oxygen sensor voltages, you need to use the graph function instead of the display function. Record a video and put it on youtube with a link to the video. Your oxygen sensor voltages should be cycling between 1 volt and zero volts - the display that you posted shows only .1 volts. If it only ever reads that you likely have bad oxygen sensors - they read close to zero when they go bad. the sensor shoudl read 1 volt on cold startup, then start cycling after a few minutes. zero volts or .1 volts indicates a full lean condition, that would cause your fuel trims to go full rich.
Here are the links to the videos. They don't really adjust much. https://youtu.be/LwF6SopBnxg https://youtu.be/JNp0oQ7tXGo |
OK, your o2 sensors are reading full lean, causing your ecu to go full rich. There a few possible reasons:
