Condensation Problem
Old Aug 19, 2011 | 03:57 PM
Take THAT, Jeep!'s Avatar
Default Condensation Problem
For a couple of weeks I've been trying to figure out why my front driver and passenger floorboards keep being wet with complete lack of rain. I've been running the a/c of course, it being 90-100 degrees every day. I haven't noticed any leaks whatsoever....until today that is. I was dropping a friend off and walked around to the passenger side and noticed a pretty steady stream of water (not antifreeze) coming out from under the plastic trim that runs between the seats. It was coming out under the trim, but behind the radio close to the glove box, where the foot vents are for heat. about 5 min later it started dripping from the same place on the driver's side. Any ideas? Is something stopped up? I did a search but didn't really find anything helpful.
Old Aug 19, 2011 | 04:24 PM
DiscoRover007's Avatar
Your A/C drains could be clogged. They are under the truck on both sides of the transmission. You will see a nipple. Some people have used a wire hanger to open then up. For me I just wiggled it a bit and a bunch of water came out. Just be careful with it.
Normally when you drive the with the A/C you should see a puddle of water when you park and return to the truck.
But you also say it came from the foot vents. I have never experienced that before so you might have something else on your hands. But the drains would be worth a shot.
Old Aug 19, 2011 | 05:16 PM
Al Blue4.6l's Avatar
dont bother trying to access the drains until the truck has been sitting for a few hours.
Old Aug 19, 2011 | 05:20 PM
not from the vents, just next to them
Old Aug 19, 2011 | 05:21 PM
I'll check the drains after the engine cools off
Old Aug 19, 2011 | 06:24 PM
Just went out and got up under it, didn't see any nipples or lines hanging down. are they black lines with nipples hanging down like I pictured? Or are they way up behind something? Are they on each side of the transmission pan area, transfer case area, where? thanks
Old Aug 19, 2011 | 06:52 PM
The most obvious one should be on the passenger side. You won't see a line, it's just a black nipple. It drips on to the back part of the drive shaft. It might take some time to find.
Old Aug 19, 2011 | 08:03 PM
They are hard to find, they will have a "X" on the end of them, they do not hang down, they just poke out of the floor on either side of the trans, under the truck.
Wear goggles because you will get a face full of water and junk.
Old Aug 19, 2011 | 10:00 PM
lordmorpheus's Avatar
Search the D2 forum for drain nipple. One of the threads has pictures of a member's nipples.
(OK, the member's vehicle's nipples)
Old Aug 19, 2011 | 10:28 PM
ralphobell's Avatar
Look at this thread with photos.
https://landroverforums.com/forum/di...s-42102/page2/
