AC Drain Points
Old Jul 11, 2011 | 10:30 AM
ralphobell's Avatar
It's your lucky day. Waiting on my y-pipe to arrive so I crawled under and took these photos. Now the y-pipe is removed and makes it a heck of a lot easier to get to.
Mine you barely had to touch to brake loose the crude and water started pouring out. So get ready to get wet.
Old Jul 11, 2011 | 10:36 AM
ralphobell's Avatar
Old Jul 11, 2011 | 12:27 PM
LundRover's Avatar
Thank so much for the photos! I was under the truck at 2am for 15 mins and could not find it.
I am still a little confused, can someone draw an arrow or mark the drain hole on the photo?
Is it Right behind the white pipe?
Old Jul 11, 2011 | 09:05 PM
ralphobell's Avatar
Default A/C Drain Plug
Yes, they are rubber nipples stick out a 1/2 inch or so. They are on the left and right side of the transmission. Get a good flash light just stick your hand up there and feel around for the nipple and squeeze. You will know when you find it. I would circle them in the photo by my photoshop is on the brink at the moment. I will try and post again later.
Old Jul 11, 2011 | 09:13 PM
ralphobell's Avatar
Old Jul 11, 2011 | 09:36 PM
LundRover's Avatar
Thank you very much! I will attempt this tomorrow morning so it easier to see. I really appreciate the photos. And I appreciate the advice on " stick your hand up there and feel around for the nipple and squeeze." lol never tried that on a car....
Old Jul 12, 2011 | 08:55 PM
ralphobell's Avatar
Any luck with the nipples?
Old Jul 17, 2011 | 09:43 AM
LundRover's Avatar
Sorry bud, am going to go try in a bit today.
Old Jul 26, 2011 | 01:45 PM
Andrew Davies's Avatar
Sorry dont have a photo but if you look for a rubber boot inside the tranny tunnel kind of inline where the pedals are, there is one on either side near the top. Look for the passenger one first, and the other is the same on the drivers side. The boot looks like a small triangle. (running it up on ramps makes the job much easier!)
bcolins
May 9, 2011 02:27 PM
rover_boy
Feb 9, 2010 07:10 AM
yarddawg
Apr 1, 2008 02:31 PM
BoostedAudi
Mar 16, 2007 09:39 PM
03se3
Freelander
Jun 2, 2005 04:07 PM
