condenser question on D2
So I had the cams replaced in my D2. I believe the mechanic took out my condenser to make room to get cams in. They said they didn't but my A/C was working fine when it went in and when it comes out it is leaking like a sieve at the connection point. I am thinking they messed up the O-rings.
They had messed several other things back and I just didn't want them tearing into it again.
I can't find any links for the D2. I don't believe I should have to remove the radiator. Just the fan and shroud. Has anybody done this?
I am going to get a new dryer to go with it with some Pag oil. I already have the vacuum pump as well as a way to measure the gas going in so that is all good, its just getting the condenser good to go or getting another one.
