cone
Old May 6, 2014 | 12:01 PM
  #21
dusty1's Avatar
yeah, I forgot about that. my morning order ship yet? I need to add another set of perches
Old May 6, 2014 | 12:10 PM
  #22
ZGPhoto's Avatar
Yeah it's all packed up etc... did you already get adapters for the shocks or are you awaiting the new ones?
Old May 6, 2014 | 12:19 PM
  #23
dusty1's Avatar
didn't get adapters yet. wasn't sure what to get.
shocks/springs should be here this week, so I can have a look at what I need. still a little concerned with the fronts not fitting (bottoming out too soon) but I still have an inch till I touch the reservoir.
Old May 6, 2014 | 12:47 PM
  #24
Fivespddisco's Avatar
Talking
Originally Posted by ZGPhoto
Retaining will limit articulation a tiny bit, but worth the peace of mind.
OK
Zack has spoken.
I have run cones for over 10 years with great success. The new lower mount cones are fantastic. You can drop the axle down as far as you like and they will always reseat.
Old May 6, 2014 | 12:50 PM
  #25
Originally Posted by dusty1
what about the xspring set up? i don't like the idea of supplemental springs, pushing my junk, but??
I have them on the P38 and do not know they are there. The Truck does better then I expected with them on.
Old May 6, 2014 | 12:53 PM
  #26
on xspring.....d1/d2 springs diameters same but d2 has the catch tab, right? so do you think they will work on either or is it truck specific? because of the seat
They will work with both a D1 and a D2
  #27
ZGPhoto's Avatar
Which shocks did you get? Did you get the eibach bump stops? You'll want them...
POLY PERFORMANCE OFF-ROAD PARTS :: Suspension :: Bump Stops & Mounts :: Eibach Micro Cellular Foam Shaft Bump Stop
Old May 6, 2014 | 12:55 PM
  #28
ZGPhoto's Avatar
Originally Posted by Fivespddisco
OK
Zack has spoken.
You're talking D2s with radius arms here, they're not like d1/d90/rrc that can keep articulating. The stupid radius arms bind and limit articulation, you'll never stretch a spring enough to hurt them on a d2
Old May 6, 2014 | 12:57 PM
  #29
dusty1's Avatar
OK
Zack has spoken.
I have a set of your X-$prings in my cart, right now. that bit of scratch could buy a $hit ton of little blue cones. is it worth it? really?
edit = you were answering as I was asking.
Old May 6, 2014 | 01:00 PM
  #30
dusty1's Avatar
POLY PERFORMANCE OFF-ROAD PARTS*::*Suspension*::*Bump Stops & Mounts*::*Eibach Micro Cellular Foam Shaft Bump Stop
done. thank you, sir
and the 12" 2.0 ( the c. valving ones, but not the r.res. ones)
