Confirm With Me What Is Leaking
Alright, I made a post a while back when I discovered an issue around the front driver side axle. Though after a little further inspection today in the sunlight this clearly is not axle grease. So what part do I need to order to solve the problem?
This, right?
Seal - Front Axle (Part # FTC4822) - Land Rover gaskets and seals from Atlantic British
This, right?
If it's not axle grease/gear oil, then maybe it's CV joint grease. You'd need a boot, clamps, and some grease.
CV Boot Kit Outer (Part # TDR100780) - Land Rover swivel ***** & parts from Atlantic British
RovahFarm for all your new Land Rover Parts and Accessories
