Connecting an oil pressure guage? and acceptable values?
Old Apr 9, 2010 | 10:12 AM
Chrisinhouston's Avatar
Default Connecting an oil pressure guage? and acceptable values?
First step in diagnosing engine tap sound:
My RAVE CD is buried somewhere on my desk. Can someone advise where to connect an oil pressure test gauge on a 2003 Discovery 4.6 engine?
Can someone also advise what are the acceptable minimum values for a cold and then a hot engine both at idle and 2000 rpms?
Old Apr 9, 2010 | 02:32 PM
lipadj46's Avatar
Under 10psi at idle is the cutoff. You attach your oil gauge where the oil sender is screwed in.
Old Apr 9, 2010 | 04:58 PM
Look at the sticky at the top of this section and read Josh's write up on setting up a guage.
Once you get it done, do a cold start, check the pressure at idle and at 2000 RPM's, then at operating temp do it again at idle and 2000 RPM's then get back to us with the 4 sets of numbers.
smokey73
Mar 9, 2010 09:14 PM
tsuami1
Aug 10, 2009 08:48 PM
mrcrptguy
Jun 7, 2009 06:01 AM
sailorcolin
Apr 18, 2008 12:33 PM
sailorcolin
Aug 17, 2007 07:27 AM
