Considering an ‘04 - help!
Old May 2, 2018 | 02:29 PM
Richard Gallant's Avatar
The trailing arm mount being re-welded sounds ominous
Coolant is a big deal it has to going somewhere - and these engines are not overheat friendly
Transfer case could be wet from the same leak as the oil pan if it is the front oil seal around 200.00 gets it done.
Power steering hoses can be a big deal as it could be the pump hoses or both.
Personally I would walk away - this truck sounds like it has had very poor maintenance and may have more hidden issues. These are expensive to repair.
The other option to make a hard offer of no more than 2500 - 3000.00 tax in - if it is not a daily driver. That gives you 2500 - 3000 for repairs and I guarantee you will have repairs.
But a quick search on Autotrader found 4 between 3000 and 6000 dollars. So if you really want a Land Rover Discovery you might want to keep looking
Old May 2, 2018 | 02:49 PM
redwhitekat's Avatar
Biggest is the coolant that would run you a few bucks
I would also walk away
Old May 2, 2018 | 02:51 PM
acg's Avatar
acg
Is this truck located on Campbell River?
Old May 2, 2018 | 03:55 PM
Canuck88's Avatar
5th Gear
Ladysmith (Nanaimo)
Old May 2, 2018 | 04:21 PM
Jeff Blake's Avatar
Pre-sale inspections include more than just an exterior scan? Like at least pulling the codes, comments on engine performance, etc.
I'd probably pass on the rust alone. Got to at least start off with a good chassis.
Old May 2, 2018 | 10:27 PM
longtallsally's Avatar
Due to rust, $2k tops. You’ll have $8k+ to make it right- and that’s before you know what’s wrong with them the motor, which could be completely wasted.
But for me, too may tell tale signs of long term use/neglect: the coolant, the rust, the dirt in certain places, the prior weld job (which I’d never trust unless x rayed). Etc. you’ll be chasing your tale for years sorting everything out.
If they wanna fire sale it, sure. But over $5k? Nope.
Old May 3, 2018 | 06:37 AM
Saturnine's Avatar
Pass pass pass pass
Old May 3, 2018 | 08:35 AM
Canuck88's Avatar
5th Gear
Thanks everyone - it’s hard not to fall in love with these, but I’ll pass as suggested and keep looking....
Old May 3, 2018 | 03:10 PM
DavC's Avatar
Doesn't Canada have the diesel Td5 for the D2?
Old May 3, 2018 | 03:39 PM
Nope we get the same as you, we are too small a market. If I could have bought a diesel I would have. There a few around but all imported.
EricTyrrell
Sep 20, 2011 03:36 PM
sjviva
Nov 2, 2009 07:22 PM
mrkbbd
Jul 18, 2006 08:10 AM
cowgirl1989
Dec 18, 2005 07:15 AM
gatorfan91
Feb 18, 2005 12:51 AM
