Considering this Disco...
Old Jan 20, 2020 | 11:10 AM
dahopes21's Avatar
4wd High
Question Considering this Disco...
Fairly new to the Land Rover Discovery 2 research and I've landed on the 2004 as the best option for me. I've been looking online over the last few weeks and I feel like I've finally found a truck that looks to be in good shape, with low(ish) mileage and the trim I want. Hoping to get some feedback from more seasoned folks about whether this is something worth pursuing.
https://www.roadstersautos.com/vdp/1...-in-Houston-TX
Old Jan 20, 2020 | 12:38 PM
NewToTheTwo's Avatar
No name, profile info etc? Location?
No price in the ad? How much is it?
Old Jan 20, 2020 | 12:45 PM
dahopes21's Avatar
4wd High
$13,999 2004 Diso II SE
124k miles located in Houston TX
There's a link to it in the above but here it is again: https://www.roadstersautos.com/vdp/1...-in-Houston-TX
Old Jan 20, 2020 | 12:46 PM
Thanks.. I can see where the truck is, I was referring to you being a brand new member and all.
Old Jan 20, 2020 | 12:50 PM
dahopes21's Avatar
4wd High
Ha! Sorry, looks like I have some profile personalizations to make.
I'm in Santa Fe NM. My name is Alex.
Old Jan 20, 2020 | 01:11 PM
cvhyatt's Avatar
Looks nice. Here are the things I wished I had checked before I bought mine:
  1. Oil leaks
  2. Coolant in the oil
  3. Stopleak in the coolant.
  4. Water temperature while running
  5. Pull plugs and check for fouling
  6. Borescope the cylinders
  7. Pull and research codes with OBD2 scanner
This is about 3-4 hours of work for a novice like me but I sure wish I had done it. I ended up replacing an engine.My 2 cents. Good luck!
Old Jan 20, 2020 | 01:24 PM
dahopes21's Avatar
4wd High
Thank you! This is the feedback I was hoping for. Very constructive.
I've seen a lot of vehicles for sale online that have been cleaned up too well, almost to a fault, because the cleaning masks a lot of the issues. I'm probably going to buy a vehicle remotely so I'll be sending a mechanic to look at whichever auto I go after. The checklist in the above reply will be helpful!
Anything else I should be mindful of?
Old Jan 20, 2020 | 02:53 PM
Best4x4's Avatar
I’d sell you my 04 in Vienna Green, black interior, 7 seater, no sunroofs, 3inch RTE lift, new shocks, extremely clean inside & out, 2 key fobs (not broken), 2 keys, and owners manual for 9k. That would include a rebuilt 4.6L engine with a crowler cam I’ll sit in the back plus the 4.6L under the hood. Engine currently in it runs excellent, but the oil light flickers once it’s warm. I just never have found the time to take the flawless 4.6L I built off the engine stand and install it. HVAC is ice cold, and everything works.
I just don’t drive it due to having 5 other Land Rovers. Those dudes in Houston are shady IMHO. They slap on cheap tires, cheap lifts, and cheap off road winches/lights and ask a TON for them.
Old Jan 20, 2020 | 02:56 PM
cvhyatt's Avatar
Just be sure you know what you're getting into. Sunroof leaks are an issue but nothing you can't fix yourself. Also note that this is an expensive hobby - even if you do the work yourself! Check out my build list cost: https://docs.google.com/spreadsheets...it?usp=sharing
I also find that a lot of folks will focus on making their Disco's look cool while neglecting the fact that there is usually a lot of repair/maintenance-type work which should take priority. Take a look at this sticky: https://landroverforums.com/forum/di...service-29020/
Old Jan 20, 2020 | 03:03 PM
Best4x4's Avatar
That cage looks flimsy to me, but thats just my opinion lol. I imagine the howling from it going down the road would be pretty bad.
