Continuing Misfires Cylinders 8 and 5 and Large Evap Leak codes
Old Aug 14, 2020 | 10:30 AM
jastutte's Avatar
Default Continuing Misfires Cylinders 8 and 5 and Large Evap Leak codes
Update:
The Rover is fixed. Initially I had replaced the coils. I still had misfires and the Large Evap Leak code. Replaced the gas cap next. This took care of the misfires but I was still getting the Large Evap Leak Code. Replaced the purge valve with the Hyundai crossover part, reset the SES and have had no problems for two weeks.
my 2001 4.0 Discovery has been misfiring on cylinders 8 and 5. the truck has always run strong and never stuttered or missed even when the SES was flashing.
but since we had the P0308 and P0305 codes the other day my son and i pulled the intake and installed new coils and spark plugs. we also had a P0455 Large Evap Leak code.
truck runs great but is still giving us the misfire codes P0308 and P0305 and P0455. today there was a new misfire code, P0304.
despite the misfire codes the truck never hiccups, the RPM's never change when the SES is flashing. i have taken it out on the highway and run it up to 70 mph. sure enough the SES flashed but performance was not affected at all. again, no stall, no slowdown, no change in the RPM's.
what should i look at next? injectors, grounds?
as far as the P0455 code goes, i have checked the gas cap. next step is the Purge Valve.
thanks,
Old Aug 14, 2020 | 10:37 AM
Best4x4's Avatar
Check for vacuum leaks, the purge control valve is usually a P0441. Could be a poorly sealed gas cap, or emission line.
Did you replace the spark plug wires? I saw coils & plugs. I recommend STI, Kingsborne.
Old Sep 8, 2020 | 10:08 AM
jastutte's Avatar
Update:
The Rover is fixed. Initially I had replaced the coils and spark plugs. I still had misfires and the Large Evap Leak code. Replaced the gas cap next. This took care of the misfires but I was still getting the Large Evap Leak Code. Replaced the purge valve with the Hyundai crossover part, reset the SES and have had no problems for two weeks.
Old Sep 28, 2020 | 02:25 PM
jastutte's Avatar
Originally Posted by jastutte
Update:
the misfires on 8 and 5 are back.
we went back in and installed new 8mm Kingsbourne wires.
i am still getting the misfires on 8 and 5 and occasionally 4.
could this be a grounding issue or could an issue with the injectors cause this?
so far, new fuel cap, fuel pressure regulator, coils, spark plugs and spark plug wires. i'm kinda lost at this point.
TennRover
Jul 8, 2019 08:01 PM
BowRat
May 10, 2018 08:09 PM
buick215
Dec 7, 2015 10:58 AM
kman35ca
Jun 9, 2012 08:32 AM
newdiso
Dec 5, 2011 08:24 PM
