Continuous audible alarm (once over 30kph)
Old Jul 29, 2013 | 03:55 AM
Daras's Avatar
Default Continuous audible alarm (once over 30kph)
Hi,
finally I am an owner of DII. Having studied the forum a little bit - i have followed the advice of "rftm" (page 72) but i could not see a solution to my problem.
The problem is ... as soon as I go over 30kph a continuous alarm can be heard. You would think it is "fasten seat belt" alarm but in the manual it says it should stop after 6 seconds latest:
Seat belt reminder
If the driver's seat belt has not been fastened
when the starter switch is turned on, a warning
chime will sound (one second
frequency). The chime operates in conjunction
with the seat belt warning light and sounds for
6 seconds, or until the seat belt is fastened
(whichever occurs first).
Any idea what this could be?
Old Jul 29, 2013 | 09:50 AM
zoso-'s Avatar
Any warning lights on? Does your truck have SLS, or was it recently converted from SLS to coil springs?
I had the same warning sound on my dads truck after converting from SLS to regular coil springs in the rear.
Old Jul 29, 2013 | 11:43 AM
Madlands's Avatar
Sounds like it has been swapped from bags to springs like zoso said. If you do have coil springs on the back then just unplug the sensors on both sides and it should stop. That's how I fixed my alarm after swapping.
Old Jul 29, 2013 | 12:28 PM
jafir's Avatar
If you go to any of the ARS rallies, I can reprogram your slabs computer to coils instead of SLS. I just have to remember to bring the scanner.
Old Jul 29, 2013 | 05:57 PM
Madlands's Avatar
Good to know! I keep trying to go to one, but ofcourse something always comes up and I have to change my plans. Whenever I finally make it to one I'll try and send you a message before hand.
Old Jan 7, 2017 | 11:46 AM
Drhuid's Avatar
Daras, did you fix the problem? What was the cause in the end?
Old Jan 7, 2017 | 04:10 PM
mollusc's Avatar
Daras posted exactly once (the message above), three years ago. I don't think you're going to get a response.
ggushee
Sep 30, 2015 08:49 AM
SolbergFanBoi
Mar 5, 2012 07:05 PM
Scooby Doo
Sep 4, 2007 11:43 AM
colwebb
Freelander
Mar 7, 2007 10:53 AM
Vincybhoy
Freelander
Mar 6, 2007 01:08 PM
