converted antifreeze
Old Oct 1, 2015 | 06:29 PM
georgep's Avatar
Question converted antifreeze
Read all the info but flushed the system 100% and went with the green stuff from NAPA. 100% then topped with well water, sorry no city water out here.
Any problems in the future or good to go.
Old Oct 1, 2015 | 06:40 PM
Joemamma1954's Avatar
Should be 50/50 mix with distilled water. If your well water is like it is here, that is the worst thing to put in there. Ours is full of sulphur, calcium from the caliche, and smells like spoiled eggs.
Your post sounds like you are joking!!!
Old Oct 1, 2015 | 06:47 PM
DiscoCam's Avatar
Yeah I hate to say it but you should flush your system out and put in a 50/50 mix of antifreeze and distilled water. Personally I think the orange antifreeze is fine but the green works too. Use distilled water next time or a premix because tap/well water is going to put a lot of calcium deposits all over your cooling system, whether it's a Rover or not.
2004 Discovery II SE Black on Black
2011 Toyota Sequoia SR5 4WD 5.7L Super White
Old Oct 1, 2015 | 09:51 PM
georgep's Avatar
I did use well water but we have a rock well that is 650 ft deep and water is tested so no junk in it.
Mixed the 100% 50/50 with water. Will see how it likes it. Have a UG so if it is unhappy will redo it ASAP.
Old Oct 2, 2015 | 11:12 AM
agthird's Avatar
you should be fine, I would be more worried about replacing the old worn out hoses and clamps...
torelle
Oct 17, 2009 03:44 PM
cpt blakesatan
Aug 17, 2009 07:31 PM
dkinder
Oct 2, 2008 06:43 PM
tee51397
Jun 2, 2008 01:53 PM
Tris
Mar 30, 2007 03:38 PM
