Coolant, 2004 Disco
Old Feb 10, 2024 | 06:20 PM
Skipperdee's Avatar
Default Coolant, 2004 Disco
What brand/kind of coolant is best for my 2004 Disco?
Old Feb 11, 2024 | 11:58 AM
Harvlr's Avatar
It’s important not to mix types. Mixing brands is okay if it’s the same type. I think most of us use the green/yellow type, like Prestone. Some use the orange type, like Dexcool.
Old Feb 12, 2024 | 11:11 AM
V50-M66's Avatar
Don't use Dexcool and don't mix coolants. Any generic green/yellow stuff should be fine, and it's what I've been running in mine for years without issue
Old Feb 12, 2024 | 11:14 AM
greisinb's Avatar
The general consensus is to do a coolant flush to get rid of the "recommended" red/orange Dex-Cool and replace it with regular green Prestone. Dexcool sludges up with oxygen contact and on a lot of these leaky D2's there's a lot of oxygen contact! Dexcool has better corrosion properties with aluminum over the long term but if you regularly change out (every 2 years) the green coolant it will be fine.
Mickey7621
Aug 10, 2021 10:00 PM
Ben Matheson
Feb 12, 2018 10:23 PM
jwbelvi
Feb 10, 2016 10:42 PM
Twncty2
Apr 21, 2013 08:01 PM
Pipedream
Oct 5, 2009 01:41 PM
