Coolant bleed screw broken, new one wont fit. How to fix leak?
Old Oct 19, 2013 | 01:07 PM
Jeff Bruno's Avatar
4th Gear
OKAY, this is nuts, and thank God I SCUBA dive...you can use a low pressure port plug from any SCUBA regulator to replace the crappy plastic thing...chrome plated brass with a silicone rubber washer !!!
Old Oct 19, 2013 | 03:21 PM
You can not use a standard screw on the tee.
Are you able to get the broken part out of the tee? If so, BMW carries that bleed screw or you can go to British Parts of Utah and buy one.
Old Oct 20, 2013 | 07:11 AM
Jeff Bruno's Avatar
4th Gear
Smile
Hi Mike, thanks for the tip. I was able to get the end out...Regarding the SCUBA LP Port screw; when I looked at the thread it looked to me to be about 3/8" and I was tempted to head to the hardware store and run it through the thread checker, but of course that wouldn't probably jive with the washer seal. It was really just a pure stroke of inspiration to try the LP screw. It fit like a charm and sealed perfectly. Of course it doesn't have that neat bleed slot on it, so I lost a little extra coolant when bleeding it...but hey, any port in a storm as they say. All that being said, I'll get on of those BMW screws though because it's longer and will grab more thread which is always more peace of mind !
Old Oct 20, 2013 | 07:46 AM
here is a Home Depot solution that was posted.
Attached Thumbnails Coolant bleed screw broken, new one wont fit. How to fix leak?-20121012_163945small.jpg
Old Oct 20, 2013 | 08:29 AM
MeanSaleen's Avatar
See this post for a DIY write up with pix https://landroverforums.com/forum/di...e2/#post293862
Do you mind reposting that link for the DIY? the link you provided doesnt lead anywhere. thanks a bunch
Old Oct 21, 2013 | 11:29 AM
Jeff Bruno's Avatar
4th Gear
That's a great idea ! And not breaking anytime soon ! I only wonder about electrolytic action
Old Oct 21, 2013 | 03:13 PM
remaximus's Avatar
5th Gear
Default Bleeder Screw
Hello;
I am new member, and definetly not as savvy as some of the senior members, but I had a situation where mine was lost while I was checking for air in the system. I was out of town, and in a pinch I removed the top bolt holding the starter on, screwed it in, and it fit. At least enough to get me home, till i could get a proper fix.
Chip
Old Jul 27, 2017 | 03:04 PM
D11dad's Avatar
Default Autozone
I know this thread is old, but, I just broke my coolant bleed screw. Dorman bleed screw p# 902-404. $4 at autozone.
Old Jul 27, 2017 | 10:04 PM
number9's Avatar
Good to know...thanks.
mvalamiko
May 31, 2013 02:34 PM
mossmanxjt
Sep 3, 2012 04:19 PM
bullcrew
Jan 22, 2012 10:39 PM
03discoman
May 9, 2010 09:46 PM
JAC
Oct 1, 2009 04:02 PM
