Coolant Boiling...no heat!
Old Apr 16, 2010 | 11:09 PM
gowest's Avatar
You don't need to pressure test it ,as it has already failed that test. It's leaking... now go find the leak..it maybe a hose but we will be guessing untill you get under there and check it. Do not let it get hot ever again....it's not like an old chevy 350 that can take the heat, it is aluminum and doesn't like to get hot.
Old Apr 17, 2010 | 04:33 PM
dharms's Avatar
4wd High
Build your own pressure tester. Use a bicycle pump w/guage. Get a presta valve from a touring bike tire. Remove one hose from the throttle body cooler and plug the side on the throttle body using a short hose, bolt and clamps. Wrap tape on the presta valve, clamp tightly into the other end of the removed hose. Pump carefully with the bicycle tire pump....I think the coolant tank cap is rated at 15psi, shouldn't need much more pressure.
(I have pictures, but the camera is back in the shop.) Can post later if there is interest.
Old Apr 17, 2010 | 05:00 PM
yloDiscoII's Avatar
I'm sure there is plenty of interest....start a new thread when you get your camera back.
Old Apr 18, 2010 | 11:17 PM
lbrover's Avatar
7th Gear
Question Found the leak
I found the leak. It's on the bottom of the radiator. I pulled this pic from the repair manual. The leak is from #22 (except on the LH side). Something to do with gear box oil? What is the function of this little thing? Do they fail often?
Old Apr 19, 2010 | 09:59 AM
Well #22 is a rubber mount, that will not leak as it is not actually part of the radiator.
Your leak is probably where the tank mates with the core.
You have two options, replace the radiator or take it out and have it repaired.
Old Apr 19, 2010 | 10:16 AM
lbrover's Avatar
7th Gear
Ok. I took the bolts out and when I lifted the radiator and put my hand where that rubber mount is, it came off in my hand the coolant poured out.
I'm going to replace the radiator. How do I get those compression hoses loose?
Old Apr 19, 2010 | 02:11 PM
lbrover's Avatar
7th Gear
Nevermind. I got it out without removing those hoses. The area where the rubber piece is was repaired previously based on how it looks. The piece broke off and it was "glued" back on...so I guess the glue finally gave up! It looks like they melted black plastic around it.
Anyway, I pulled all the "glue" off and there is a hole.
I ordered a new radiator. Luckily I have another vehicle to drive while I wait!
Thanks for all your help. I'm so glad it was just the radiator!!
Old Apr 19, 2010 | 04:49 PM
Dont you just hate half a ssed repair jobs?
Old May 31, 2010 | 04:37 AM
Up N Over's Avatar
6th Gear
G,day all, I am having a simluar heating issue as Ibrover. Why the hell someone would put a header tank lower then the top hose on a motor has got me buggered. My 1954 landy has a radiator cap on it and it works, my 1980 landy has a cap it works, my 1989 rangie has a bleed pipe that sits up nice and high gets all the air out on prob it works, 10 years on and my 1998 disco has f/all, no way of bleeding the air out easy, fill the system with water and the top hose will be empty every time. Need people to build cars with some idea of what the vehicle might have to do in its life, not just look pretty. yes I'm pissed off.
Old May 31, 2010 | 05:00 AM
cranky's Avatar
Hey UNO,
I think you can get a replacement with a bleed screw in it.
Sale Vic? Try roverparts.com.au - they're over in Ballarat.
________
Problems From Nexium
Twncty2
Apr 21, 2013 08:01 PM
taylorRIchie
Jan 2, 2013 09:27 PM
blast20
Jul 16, 2011 09:32 PM
mattrickman
Aug 26, 2009 05:33 PM
bigfun
Dec 13, 2007 04:23 PM
