Coolant draining out of overflow after driving..
Old Apr 10, 2014 | 04:28 PM
Rocko99's Avatar
Default Coolant draining out of overflow after driving..
Bosses 2000 D2 was 2 gallons low on coolant. He said there was no puddles, leaks. I filled the coolant up using the methods described here. Let the car heat to normal temps. A bit drained out the overflow tube. Drove the car for 20 minutes, did not overheat, turned the car off and within a couple of minutes coolant was pouring out of the overflow tube and I heard a boiling sound. Any ideas where to begin?
Owner got this car a few months ago and the head gasket was replaced 20K miles ago. No leaks in the system, hoses are all good.
Old Apr 10, 2014 | 04:32 PM
dusty1's Avatar
real time gauge, like ultra or scan or something is needed so he can read the actual temps.
Old Apr 10, 2014 | 05:03 PM
Rocko99's Avatar
I don't have access to that, but I do have infrared thermometers.
Old Apr 10, 2014 | 05:06 PM
ralphobell's Avatar
Do you have access to an obdii code reader with live data?
Old Apr 10, 2014 | 05:29 PM
Rocko99's Avatar
Ok, top hoses are all around 185F, thermostat and hose below is 107F. I assume it's not opening up....
Old Apr 10, 2014 | 05:33 PM
Rocko99's Avatar
Not with the live data. Just a standard code reader.
Old Apr 10, 2014 | 06:35 PM
jfall's Avatar
Step 1
Replace radiator with Nissens radiator from rockauto.com
Replace thermostat with low temp 180 degree Rover thermostat (not a Motorad)
Replace fan clutch with a HD Hayden from ebay - get a NEW one.
IF you STILL have antifreeze blowing out the coolant tank
Replace head gaskets.
Done.
Old Apr 10, 2014 | 06:59 PM
Rocko99's Avatar
Radiator, all hoses, and fan clutch were replaced last year. Head gasket 20K miles ago. It's not my car, but I do have the records for it. Thermostat looks to be a light brown if that matters.
ewatk
Jul 9, 2020 05:17 PM
junya
Aug 12, 2011 08:24 PM
bigfun
Dec 13, 2007 04:23 PM
SpeedAgent
Jul 14, 2007 10:19 AM
MARGE
May 25, 2007 11:24 AM
