Coolant dripping from the rear of the motor
Old May 4, 2022 | 10:14 AM
Brandon318's Avatar
If it's running down the back of the block, sorry to say but it's very likely the head gasket. I was in denial about this for the last few years until finally replacing every cooling system component (they were about due anyway) and then finally conceding and replacing the head gasket. Sure enough. The smallest weep out of the back coolant jacket. All cooling system problems have been fully solved since.
REPLACE COOLANT REGULARLY. The prior owner of our 2002 maybe replaced coolant once, and when coolant gets old, it becomes acidic and starts to eat away at aluminum bits (i.e.... your block) and will eventually chew right through the already anemic head gasket.
Old May 4, 2022 | 12:57 PM
PickleRick's Avatar
Originally Posted by mln01
More typically a TBH leak can run along the valley between the head and the intake and drip off the back of the engine.
Or, you can just borrow a cooling system pressure test kit from one of the auto parts stores.
​​​​​​ I live in the sticks so it's nice to be self sufficient. Plus it works on everything from pressure testing a carb, brake boosters, etc. If you can block it you can test if for leaks.
Old May 7, 2022 | 06:24 PM
me 2's Avatar
Found the culprit. I bypassed the tb cooler and the skinny hose coming from the top of the front intake manifold that goes to the coolant reservoir had a good leak. Hose clamp wasn’t tight enough. Also had a leak on same hose at the bottom of the coolant reservoir. Thanks guys for the ideas.😁
Old May 8, 2022 | 07:54 PM
mln01's Avatar
That line means the throttle body heater has been bypassed (and it was a TBH leak, of sorts). You can bypass it even more effectively by simple eliminating that circuit. Just plug the line at the reservoir and at the intake and be done with it. Plugging it = a short bolt stuck in the hose and secured with a small hose clamp.
Old May 9, 2022 | 12:56 PM
Motorhead1's Avatar
That line means the throttle body heater has been bypassed. (And it was a TBH leak, of sorts.) You can bypass it even more effectively by simple eliminating that circuit. Just plug the line at the reservoir and at the intake and be done with it. Plugging it = a short bolt stuck in the hose and secured with a small hose clamp.
I've never heard of anyone capping these off? I use a piece of 5/16" fuel line to run from the manifold to the expansion tank
Old May 10, 2022 | 04:46 AM
mln01's Avatar
Well, now you have!
The coolant flow diagram shows that the sole purpose of that coolant circuit is to supply the throttle body heater (labeled 6 and 7 in the diagram). If you choose to bypass the TBH there's no need for that line.
Cburns28
Jan 7, 2021 12:33 AM
ls1morethanyou
Nov 2, 2015 07:40 PM
me 2
May 24, 2012 11:39 PM
Cessna310Guy
Nov 21, 2008 10:38 AM
ryanljcom
Aug 28, 2008 06:55 PM
