Question for those that have pulled there motor out
Old May 23, 2012 | 04:38 PM
me 2's Avatar
Default Question for those that have pulled there motor out
Im pulling mine out this weekend and wondered if it would be easier to pull the motor out with the tranny attached or without? Thanks for any help.
Old May 23, 2012 | 04:41 PM
Just curious, what is wrong with your engine.
I would remove the tranny first.
Old May 24, 2012 | 07:06 AM
drowssap's Avatar
just unbolt the motor, otherwise your talking about the tranny and transfer case, dropping the cross member and drive shafts its a lot of extra work if you dont have to.
remove the motor mounts and lower the motor on a floorjack and you can reach the top bellhousing bolts easily.
Old May 24, 2012 | 12:38 PM
me 2's Avatar
Default stuff
Thanx guys, hey Mike, found that the coolant was getting into cyl 6. Cracked block or sleeve issue.
Old May 24, 2012 | 11:39 PM
0304Disco's Avatar
Gotta pull just the engine. Don't think you would even have the room to remove them attached together. Pull the engine mounts, lower the engine down and then remove the upper trans to engine bolts.
clang
Nov 12, 2015 12:17 PM
StormTroopa
Nov 28, 2009 06:45 AM
tornado_735
Mar 6, 2009 08:53 PM
disco12
Mar 19, 2006 03:48 AM
