coolant flush, head gasket leaking
Old Nov 28, 2008 | 12:08 AM
ne1949mozda's Avatar
Default coolant flush, head gasket leaking
hi guys I dont know nothing about cars.
antifreeze wasleaking on my 2003 Discovery so I went to mechanic to see what is the problem.mechanic told me he needgasket and hose so would be about $220 ok no problem.
he did at same time coolant flush $80. next day I start car to worm up I notice antifreeze is leaking bedly went back the same mechanic. what is the problem now?
mechanic told me it is head gasket leaking antifreeze. mine question is did mechanic F up car!
Old Nov 28, 2008 | 08:05 AM
Default RE: coolant flush, head gasket leaking
If he told you you needed head gaskets, why didn't you do them??????????????????????
How many miles on your truck?
Plan on $1600 for head gaskets plus head work if you over heated your engine.
Old Nov 29, 2008 | 06:39 AM
Cessna310Guy's Avatar
DiscoMike, no means am I trying to step on your toe's here.... where's the leak coming from... I just did my Valley Pan Gasket and it was leaking from up top and then running down to the bottom of the bell housing and splattering off the crossmember bar... if it's doing that then I would say it could be what I found... Valley Pan Gasket... Just A thaught... I am no mechanic but am somewhat mechanically enclined and this took me about 12 hours to complete along with an extra set of hands
Old Nov 29, 2008 | 05:48 PM
No your mechanic did not mess up your car.
Blown head gaskets are a certainty on DII's.
Old Nov 29, 2008 | 06:06 PM
jkid's Avatar
Did it ever overheat at all? What gasket did he replace?
Old Dec 2, 2008 | 11:56 PM
no ,did not at my knowledge. he fixed! now I have another problem.
Old Dec 3, 2008 | 10:12 AM
So it is safe to say you really don't know what your mechanic did to your truck for $220, it certainily wasn't headgaskets.
What is your current problem and what exactly did this guy to your truck the first time around. Without that information it is hard for us to try and help you.
Old Dec 4, 2008 | 12:53 AM
Disco Mike,
yes you are right. it was intake at first time I went to fix, but when was leakin again he told me it's headgaskets. car was at shop for 7 days he called me and said we have little problem multiple missfire codes. so they towed the car to land rover dealer.
problem was spark plug wires and installed incorrectly and missing parts. mechanic I went to fix car in first place for leaks I dont know what he did for 7 days! he did not charged me anything for second time leak or towing.
I end up paying land rover dealer $1,100.00 to fix.headgaskets have not been touched that what mechanic told me at land rover dealer.
I ask mechanic how you can tell he said by screws it is old ones.
you guys tell me who to believe!
Old Dec 4, 2008 | 07:34 PM
Sounds like the first guy put it back together wrong.
I nwould not let him work on it again.
Old Dec 4, 2008 | 10:15 PM
I dont trust that guy no more.
