Coolant Flush Inquery
Old 05-19-2007 | 12:42 PM
puchungozback's Avatar
Default Coolant Flush Inquery
Hi... I would like to know how to remove the old coolant from an 03' Disco. I have some crappy green stuff in there and as intructed by mike it should be taken out. However I do not see a drain plug or screw anywhere. The bottom seems pretty well covered up with the exception of a circular hole to access the oil drain. Im not too mechanical but have change oil before on other cars thats about as far as I can go. Is there a way to drain this coolant that doesn't require disassembling other stuff. Any info would be great... THANKS A BUNCH...
Old 05-19-2007 | 01:52 PM
Default RE: Coolant Flush Inquery
About the only thing you can do is remove the lower hose at the t/stat and drain it out, there is no petcock.
Don't use any more green coolant, DexCool only.
Mike
Old 05-26-2007 | 12:26 AM
gtagg's Avatar
I think.. you'll also have to remove the engine plugs, on each side of the block. especially if you have the wrong coolant in it. as well as what Mike said, it the only way, it takes a lot of anti-freeze you might change out the t-statwhile your at it. dex-cool
Tagg
TRIARII
02-08-2013 02:15 PM
ShadowMerchantBC
06-10-2011 04:20 PM
ShadowMerchantBC
06-07-2011 10:59 PM
ShadowMerchantBC
05-07-2011 10:08 AM
DeepBlueWater
11-16-2007 03:10 PM
Quick Reply: Coolant Flush Inquery
