Coolant Hose Blew
Old Oct 30, 2014 | 07:36 AM
steb4680's Avatar
Default Coolant Hose Blew
One of my coolant hoses came off and took out the fan, fan cover and upper and lower radiator mounts. What would cause so much pressure to make a hose pop off. Could it be a head gasket? I am at a loss right now.
Attached Thumbnails Coolant Hose Blew-image-2834089022.jpg   Coolant Hose Blew-image-800198475.jpg   Coolant Hose Blew-image-2292269222.jpg   Coolant Hose Blew-image-848929045.jpg
Old Oct 30, 2014 | 08:03 AM
drowssap's Avatar
hard to say, looks like everything's original in there, hoses, clamps and t-stat.
Old Oct 30, 2014 | 09:06 AM
agthird's Avatar
could have been the fan that came apart taking out the hose. Bad water pump bearing?
Old Oct 30, 2014 | 09:21 AM
steb4680's Avatar
Just replaced the water pump. Could it have built up too much pressure making the clamp fail and the hose coming off. Thermostat housing bevels are shot.
Old Oct 30, 2014 | 12:49 PM
lordmorpheus's Avatar
I was just about to mention the thermostat housing bevel looking disintegrated...
Old Oct 30, 2014 | 03:44 PM
steb4680's Avatar
It is cracked and not much bevel is left. I guess I can buy the 180 degree thermostat and the hoses are not cracked or damaged.
Old Oct 30, 2014 | 05:18 PM
Motorhead1's Avatar
Originally Posted by DarylJ
These trucks have their own weaknesses, but they are far from "screwed up". Here's why you hear about so many problems:
- You just bought a 10 year old luxury vehicle for a couple thousand dollars. Use your head: why did it depreciate the much? Because its a maintenance pig.
- They are not Chevys. They require more maintenance if you want them to run well. The part costs are higher, so lack of maintenance get expensive quickly.
- They are not Chevys. You won't find 10 to 20 of your exact model in every junk yard to pick used parts off of.
- They are worth so little now that irresponsible people can afford to buy them and trash them.
- They are worth so little now that someone who otherwise maintained theirs see it as basically disposable, to be dumped on a used car dealer when something goes wrong. This puts them into the auctions, and from the auctions they end up being sold through small maybe not so reputable car lots as well as "private sellers" who aren't really private sellers.
I only modified about 3 words of that explanation from when I used it to explain the exact same question about older Porsches.
I though this was a good read...very true. From the looks of your T-Stat, I would replace all the hoses too...Your due for some maintenance
Old Oct 30, 2014 | 08:03 PM
Fivespddisco's Avatar
I would put the thermostat in and run the truck with the overflow tank cap off.
What you're looking for are bubbles not the little ones from movement. If you see big burping bubbles. If the head gasket is going bad it can force gas into the coolant system is maybe the reason you're hose exploded
Old Oct 31, 2014 | 05:19 AM
potxoli's Avatar
see my thread. Same thing happened to me:
https://landroverforums.com/forum/di...me-help-68530/
It could be that the fan took out the hose instead of the other way around.
Old Oct 31, 2014 | 09:22 AM
steb4680's Avatar
I think I am going to buy a new fan, thermostat, hoses, and I just saw the return line nipple on the radiator is trashed so I will buy a new radiator. I have done lots of work to it already so hopefully she will run a while after this issue is resolved. I don't mind doing maintenance on it but this problem left me stranded. I appreciate the info and I am aware that this is no Chevy.
