Coolant hose pipe broke please help ASAP I need a quick fix
#23 is the black plastic pipe Im referring to. One end connects to the coolant expansion tank, the other end travels along the radiator, loops around next to the engine air box then fits into a 1 inch long rubber hose which in turn it connected to the side of the Radiator.
Discovery II Cooling & Heating - Rovers North - Classic Land Rover Parts
Ok I gotcha now. I thought of the pieces on the expansion tank or radiator had broke. That same hose broke on me 2 thanksgivings ago. If you can find a part store open go buy like 8ft of fuel line hose or something similar. You won't need exactly that length but you can cut off extra later. Replace the entire plastic hose with the new hose.
The easier way is to Cut the old rubber hoses off the radiator and expansion tank with a razor blade because it'll be too baked on to pull off. Slide on you new hose to each end, clamp, and go enjoy thanksgiving.
whurst79
01-28-2013 09:24 PM
ssblast20
02-25-2012 07:55 AM
bcolins
06-02-2011 07:40 PM
oysterhead
05-16-2011 10:42 AM
