Coolant Leak
Coolant Leak
Hey guys!
New here & new to cars in general 😄
I have coolant leaking from around here on my 1999 d2. It makes a noise where it sounds like its squirting out under pressure, this noise happens intermittently when driving. By the photo it looks like that’s what’s happening here as the spray has cleaned off some of the bell housing. You can see drops of coolant on the plugs and rails there.
Does anyone know what the plug where the rail enters into the transmission on the right? (Second Photo) Or has anyone had a similar issue to this, in this area?
Steam cleaned half of bell housing
What is the rail called that enters into the bell housing on the right? I believe its leaking from there
Thank you, Tom
Thank you, Tom
Joshman
04-16-2013 11:48 AM
