Coolant Leak Help Needed
Old Jan 28, 2020 | 06:00 PM
SP543's Avatar
4wd High
Default Coolant Leak Help Needed
Purchase a 2006 LR3 2 months ago, currently has 120k miles. Noticed a small pool of coolant under the car while going to grab dinner this evening, checked coolant levels and it was low in the reservoir but not bone dry. Checked for active leaks, but the only coolant I could find other than that on the ground and skid plate was this small pool near the top of the motor just under the engine cover. Is this the thermostat housing that I heard can eventually crack, leaking? Or somewhere else I should check? Doesn’t appear to be the coolant T either. Thanks
Old Jan 28, 2020 | 07:12 PM
The thermostat housing is a possible culprit and likely from what I am seeing.
Old Jan 28, 2020 | 07:19 PM
SP543's Avatar
4wd High
Yes, just did some more searching and everything I’ve read is pointing to the thermostat housing as well. I’ll likely end up doing it myself, but what would/should an independent shop charge to replace it?
Any issues using this housing that’s a fraction of the cost of the LR Genuine part?
https://www.amazon.com/Topaz-LR005631-Coolant-Thermostat-Housing/dp/B06VV39CJS/ref=mp_s_a_1_5?keywords=lr3+thermostat+housing&qid=1580260521&sprefix=lr3+ther&sr=8-5 https://www.amazon.com/Topaz-LR005631-Coolant-Thermostat-Housing/dp/B06VV39CJS/ref=mp_s_a_1_5?keywords=lr3+thermostat+housing&qid=1580260521&sprefix=lr3+ther&sr=8-5
Old Jan 28, 2020 | 07:57 PM
DakotaTravler's Avatar
Unless you want to do this again, go genuine. I have read more than a few times the aftermarket ones ended up cracking or failing in short time. Keep in mind its more than a plastic part when you buy one. It has a new temp sensor and a whole new t-stat. So its a pretty robust part. So if you go cheap, its not just the housing that may be sub-par, but the other bits. Also keep in mind shops hate it when people bring their own parts, so I would venture if you want to save some cash you can indeed do this yourself. Its not terribly difficult.
Old Jan 28, 2020 | 08:34 PM
100% agree on going genuine
Old Jan 29, 2020 | 08:06 AM
SP543's Avatar
4wd High
For those who have done the replacement - any recommendations on specialty tools/extensions/etc outside the norm that will make it easier?
Old Jan 29, 2020 | 04:40 PM
Honestly the best thing for it is patience. A couple bolts are a bit fiddly that attach it to the heads. Nothing to crazy that I remember needing when I did one a couple years back
Old Jan 30, 2020 | 03:19 PM
abran's Avatar
a few 1/4" extensions and a 1/4" 8mm universal joint socket. There are 4-8mm bolts that hold the throttle body that need to be removed. The rest is gravy.
grapple
LR4
Feb 15, 2020 01:24 AM
Amberslaws
LR4
Oct 1, 2019 11:48 AM
leddifer
Oct 27, 2010 06:33 PM
rick.miles
Freelander
Dec 20, 2008 06:21 AM
jerome
May 21, 2007 04:26 PM
