Coolant(?) leak - engine bottom
Old Feb 29, 2020 | 12:18 PM
dwoodskc's Avatar
Default Coolant(?) leak - engine bottom
I have a leak that I think is coolant (my coolant is low and the liquid looks orange). it’s hard to see from this picture, but it almost looks as if there is a leak at the gasket(?) that joins the bottom metal plate to the bottom of the engine. I just had the thermostat and a coolant hose at the top of the engine replaced, but I don’t see any leaks at the top.
Old Feb 29, 2020 | 02:03 PM
Richard Gallant's Avatar
Clean it all up,
start it up
then see if you can see where it is at
Could be the water pump weep hole
Old Mar 1, 2020 | 10:17 AM
Brandon318's Avatar
I'd recommend renting a pressure tester kit from auto zone or oreilly. Super easy to use, and simulates pressure as if the motor is running. Really easy to spot leaks that way.
Old Mar 1, 2020 | 03:27 PM
Llamasayswhat's Avatar
That looks like very clean engine oil.
A coolant leak making it down that low, especially after running over all the oil and sludge on the front of the motor would look nasty and milky
Old Mar 1, 2020 | 04:30 PM
dwoodskc's Avatar
I cleaned everything and drove it yesterday. The bottom still looks clean and doesn’t seem to be leaking much. There are a couple drops but I think that’s a power steering fluid leak I know about already. I guess I’ll watch it.
Old May 5, 2020 | 06:08 PM
LeatherBoots's Avatar
I think we had the exact same issue. My TB was leaking and mixing with surface oil. It made it seem like there were 2 leaks but I could never find the second leak. The coolant was dripping down the back and getting everywhere The TB hose was going out. I tightened it up and it stopped it but it came back and needed a replacement. replaced it and no more issues. It will drip all over your CPS.I sprayed brake cleaning fluid all over to clean up the mix.No more issues from it. .
Old May 9, 2020 | 10:02 AM
dwoodskc's Avatar
I think mine was a power steering leak. I tried a different type of stop-leak fluid and it worked. No drips at all now.
Old May 9, 2020 | 10:57 AM
redwhitekat's Avatar
if you still have that dexcool crap get rid of it
SP543
Jan 30, 2020 03:19 PM
boomerjackson
Oct 22, 2019 09:13 AM
fleacz
Sep 18, 2018 01:21 PM
huggi
Nov 8, 2016 10:34 PM
thearndtfamdisco
Apr 30, 2010 10:41 AM
