Coolant Leak
Old Jan 11, 2008 | 02:17 PM
gsgtsg's Avatar
Default Coolant Leak
My Discovery II year 2000 Petrol V8 has been experiencing a coolant leak. The coolant reservoir level dropped by an inch every 400 miles or in a week driving in town.
I have had it pressure tested and the garage said that the leak is from the component that I have ‘circled’ in green on the attached pictures. The component is in the location where the white arrow points on the full engine photo.
Please advice:
1) What this component is called
2) What is its function
Thank you.
Old Jan 11, 2008 | 03:01 PM
jmt's Avatar
jmt
Default RE: Coolant Leak
Pics were a little hard to see. Reposting for you:
Old Jan 11, 2008 | 03:13 PM
98roverguy's Avatar
ORIGINAL: gsgtsg
Please advice:
Thank you.
1) Throttle body heater plate. http://www.roverparts.com/Parts/MGM000010KG.cfm
2) To warm the air as it passes through the throttle body.
Old Jan 11, 2008 | 03:39 PM
gsgtsg's Avatar
Thanks for the picture of the component. Is it easy to replace without having to flush and replace the coolant?
Old Jan 11, 2008 | 03:46 PM
98roverguy's Avatar
Because it's as high as it is, you'll lose a little coolant but not much. Just capture what comes out, dry it, install and top it off. You'll also want to bleed the system. Remeber to use the right coolant -Dexcool.
Old Jan 11, 2008 | 09:32 PM
You just need to replace the gasket to stop the leak. I hear that this is a common problem and that there is a repair kit for cheap at the dealer and you can fix it yourself if you are half way mechanical.
Old Jan 11, 2008 | 10:05 PM
sideburns's Avatar
I would recommend replacing the bypass hoses that attach to the throttle body heater plate, they leak as well
Old Jan 12, 2008 | 04:48 AM
starcraft's Avatar
I took the easy way out andsimply took a piece of 1/4' copper pipe and connected the two hoses together (make a "U" shape so that it fits properly). That gasket is problematic and you don'tneed the system so why bother. Hope that helps.
Old Jan 12, 2008 | 08:45 AM
You dont need it unless you live in really cold weather. It is to prevent icing of the t-body.
Old Jan 12, 2008 | 09:01 AM
I have 0 degree starts, here in Colorado nad mine has been by-passed for the last 3 plus years with no side effects.
