Coolant Leak
Old Jan 12, 2008 | 09:24 AM
Default RE: Coolant Leak
The t-body heater has nothing to do with cold starts. There is no heat to it until the engine is warm.It is to prevent icing when the enigine is warm and you are in very cold temps sucking in moister laiden air.
You know when the front side of your mirriorsice over when you are driving on the highway but it isint snowing? Your t-body does the same thing. Carb's used a hose that came off of the exhaust manifold and went to the air cleaner. Remember that little foil tube that always got lost or broken everytime you worked on the car? Thats what that was for. To keep the carb from icing up.
For most of usthe t-body heaterisint nessasary. But for those who live in cold wet area's it is.
You can do what you want, it is your trk. If you want to set it on fire go for it. If you want to by-pass the t-body heater, go for it. My point is that it is there for a reason. Thats all.
He asked what it was called and what it was for.
Old Jan 12, 2008 | 10:34 AM
geotrash's Avatar
ORIGINAL: Disco Mike
I have 0 degree starts, here in Colorado nad mine has been by-passed for the last 3 plus years with no side effects.
In Coloradowe can get away with it because it's dry. In a high humidity situation like ice fog, icing on the throttlebody could be a problem because it acts like a venturi and moisure can condense out of the air. Not common, but it can happen.
In piston-engined aircraft with carburetors, venturi icing after startup and when flying in clouds can be a serious issue. All such aircraft engines have a carb heat **** that redirects air from a jacket around the muffler to the intake air stream to bring it above freezing and prevent ice buildup. Same idea. I've experienced carb icing 4 times in the last 4 years (Cessna 182s are notorious for it). Definitely gets your attention if it happens over, say, Rollinsville
Dave
Old Jan 12, 2008 | 02:40 PM
gsgtsg's Avatar
Thanks all,for the information.
Old Feb 3, 2009 | 05:08 PM
motozine's Avatar
6th Gear
Mine leaks too so bought gasket but i can't fine exact size of ranch that fits small bolts it's holding.
Looks like 3 bolts there. can someone help what's the exact size? doesn't seems it's metrics, 6mm too big, 5mm too small....arrrrr
Old Feb 3, 2009 | 06:02 PM
Luv2Disco's Avatar
Use a 5.5mm wrench. Go ahead and bypass it though. You won't need it (unless you live in Grand Rapids, Mi) and it's just gonna leak again....I'd bet money on it......
Sorry Spike....couldn't resist..... 72 degrees forecasted for down here this coming weekend!
Old Feb 3, 2009 | 07:20 PM
Yeah but in Texas you cant ski or snowshoe.
It's going to be 40 here this weekend, warm enough for shorts!
Old Feb 3, 2009 | 11:14 PM
Luv2Disco's Avatar
ORIGINAL: Spike555
Maybe so but you could skate on my street last week after the ice storm.
Iwill admit that I do miss a snowy day now and then. And, up north, you get the evergreens to add some color to the landscape. White and Greenare much more pleasant than our grey and brown.
Phil, about those shorts, give us a warning if you post pics.....I'll want to put my shades on before viewing.
Old Feb 4, 2009 | 07:27 PM
Does this make you want to come back home Dana?
Holland Sate Park two weeks ago, the lake is frozen almost all the way to Wisconson.
Old Feb 4, 2009 | 11:25 PM
Luv2Disco's Avatar
You always feel that need to return home. At least I do. And great pics! I like how theshafts of light are breaking through the clouds with thebirds adding movement.
So, you ever think of takingyour Disco on the shortroute to Wisconsin?Skip all that pesky Chicago traffic...maybe< two hours with smooth ice....
Old Feb 10, 2009 | 04:29 PM
motozine's Avatar
6th Gear
I'm thinking about bypass.
piece of 1/4' copper pipe
by the way is it 1/4 O.D (outside diameter) or I.D pipe to use?
thanks.
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
