Coolant Leak
Old Dec 2, 2008 | 03:38 PM
ajordan_0012000's Avatar
Default Coolant Leak
I have a coolant leak under the Throttle Body settling on the top of the engine block any idea?
Old Dec 2, 2008 | 06:23 PM
Default RE: Coolant Leak
http://www.roverparts.com/Parts/ERR6623.cfm
Very common and a easy DIY fix.
Old Dec 2, 2008 | 07:23 PM
You need to start reading up on your problem before you post a question that has been answered as many times as that one has.
Old Dec 3, 2008 | 04:01 PM
Thanks. Is there a diagram showing the location of the Gasket Throttle Body Heater
Old Dec 3, 2008 | 04:14 PM
NiteTrain's Avatar
ajordan, unless you live in a very cold climate you dont really need the throttle body heater..I disconnected and plugged mine off.
Old Dec 3, 2008 | 06:25 PM
Where do I plug the line off at. Just wanna stop the small coolant leak. I live in Atlanta, Ga. Thanks
Old Dec 3, 2008 | 06:59 PM
NiteTrain's Avatar
ajordan, I just disconnected the hoses at the throttle body and left the ports open...I put a bolt in the line coming from the coolant reservoir..if you need me to I can take a pic of mine.
btw, I'm up in woodstock..you ever do any off-roading with your rover?
Old Dec 3, 2008 | 09:23 PM
Remove the air intake tube from the throttle body, you will find two coolant lines going to the bottom of the t-body, that is where your t-body heater plate is.
Unbolt it, replace the gasket, re-attach, done.
It is a $3 part and a 15 min job.
Old Dec 3, 2008 | 09:34 PM
sloppyjoe's Avatar
why does rover insist on all these little goofy things that go wrong inevitably?
Old Dec 3, 2008 | 09:46 PM
NiteTrain's Avatar
It probably does not matter if you remove the plate or not. However, there might be a chance removing that plate could decrease the speed of the air within the throttle body assembly and negatively effect performance.
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
