Coolant Leak
Old Oct 17, 2010 | 03:42 PM
chuck32259's Avatar
6th Gear
Default Coolant Leak
I have a coolant leak on my 2003 Disco. It appears to be coming from somewhere behind the A/C compressor. There is a hose there but I am unable to tell for sure if that is where it is leaking. It only leaks when the engine is running.
Thanks in advance for any advise.
Old Oct 17, 2010 | 04:10 PM
Sounds like it is the throttle body heater gasket leaking, very common leak on DII's.
Go to the write up section on the top of the DII page and read through it.
It is a pretty easy DIY, $25.
Old Oct 17, 2010 | 04:17 PM
chuck32259's Avatar
6th Gear
Thanks Spike! I read about that earlier and checked right away but it is leaking farther to the left behind the compressor.
Old Oct 17, 2010 | 04:36 PM
You are going to have to pinpoint the leak, there are 2 coolant hoses that run to the t-body heater and they can become brittle and crack.
Take a flash light and remove a few things if you need to so you can see better.
Once you find it let us know.
Old Oct 17, 2010 | 04:48 PM
chuck32259's Avatar
6th Gear
That was my next step was just wanting someone to reassure me it was the best thing to do. Thanks Spike!
Old Oct 17, 2010 | 06:30 PM
You are on the right track.
Keep us posted.
Old Oct 27, 2010 | 08:57 AM
chuck32259's Avatar
6th Gear
I unbolted the A/C compressor and moved it to the side. As soon as I did I saw the problem. There was a hole in the Expansion Tank To Throttle Hose. Ordered a new one and it should be here today.
http://www.roverparts.com/Parts/PCH000420G.cfm
Old Oct 27, 2010 | 09:06 AM
agthird's Avatar
if the hoses have never been replaced now would be a good time to do them all...
Old Oct 27, 2010 | 03:35 PM
Do you know how to bleed the coolant system after replacing that hose?
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
