Coolant Leak
Old Oct 28, 2010 | 10:51 AM
jmjibboo's Avatar
Default Coolant Leak
I finally found where my coolant is leaking from. But, I have no idea what part this is. It is not leaking from the hose. There seems to be a crack in the part behind the hose. When warmed up, orange bubbles fizz from the crack (dexcool, I assume). Can anyone help me identify this part and give me an idea of repair costs?
Thank You!
Old Oct 28, 2010 | 11:04 AM
boris_gti's Avatar
Here you go!
http://www.roverparts.com/Nxt/search...s=heater+plate
Pick one!
You might want to take your throtle body off. It is much easier to clean the surface. Make sure you purchase the throtle body gasket in that case. They are only 2-3 bucks.
Old Oct 29, 2010 | 08:12 PM
jmjibboo's Avatar
Thank you very much, boris_gti! With such a little price difference, should I go with the genuine part? Or does it matter?
Old Oct 29, 2010 | 08:37 PM
buick215's Avatar
They are probably equally as good, but since the difference is so little I would go with the original.
Old Oct 29, 2010 | 10:07 PM
ccombrink's Avatar
That is what leaked out on me and caused a HG job. I think there is an upgradable version for those...I would go OEM.
Old Oct 29, 2010 | 10:41 PM
JerrodSteph's Avatar
I just got done doing the exact same job on mine, I bought the heater plate kit from rover and it ended up being just a split hose from an overtightened hose clamp! I found out after I put the new plate on when it then was really spilling some coolant all over the valve cover then onto the cat. I just cut the section of hose with the split and stuck the thing back on it has no leaks now and a new heater plate for no reason, oh well it was going to leak anyway eventually right?
Old Oct 30, 2010 | 10:01 PM
boris_gti's Avatar
When I ordered mine, the guy from the store shipped the cheaper one for some reason. It worked out good anyways. I would still order the throtle body gasket as well because it makes the job much easier once you take the throtle body completely off. You can clean the throtle body at the same time as well.
Old Oct 30, 2010 | 10:47 PM
bosshogt's Avatar
  • Replacing the throttle body gasket is not necessary when you remove the throttle body. You can always cut one from a make a gasket roll. as I have removed mine and it went back on and came off without hurting the gasket.
  • While doing all this work, I would replace all the mini hose clamps with the worm drive style. 2 leaked after completing my throttle gasket job. I wish I would have taken the extra time to replace all easily visible the first time. You can skip the hose on the hard plastic lines on the coolant over flow tank.
Old Oct 30, 2010 | 11:59 PM
Rover just released a 3rd. up-dated replacement, get it for a better chance of it lasting longer. Make sure you do a full coolant system bleed after replacing the parts.
Old Oct 31, 2010 | 12:44 PM
jmjibboo's Avatar
Thank you for all the great advice! You've helped so much!
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
