coolant leak
Old Apr 4, 2012 | 09:07 PM
kmyer01's Avatar
Default coolant leak + p1668
Ok guys i need a little help. I have been fixing coolant leks since I got my land rover last summer. I did the head gaskets around december, and I have replaced most all the hoses...so I thought great its finally over but now I have found leaks at the back of both heads. crap! I just need so ideas on where to go from here. thanks.
Old Apr 4, 2012 | 09:12 PM
Valley pan corners? And were heads machined during HG replacement?
Old Apr 4, 2012 | 09:14 PM
kmyer01's Avatar
yeah the heads where machined. it seems to be coming from the middle of the heads at the back.
Old Apr 4, 2012 | 11:44 PM
jfall's Avatar
Don't laugh at this..
You'll be hard pressed to find the leak quickly.
Put in a standard bottle of Barr's Leaks.
Jaguar used to run it standard in cars a lot more expensive than Disco's.
As long as it is not a head gasket, Barr's leaks will plug it.
I have been running it in our Discovery I for a few years now.
Does not plug the radiator and heater core. And, no leaks.
Replaced the head gaskets in the Disco I and head a few misc leaks.
Put in Barr's Leaks and - well, no green or orange on the ground now.
It is the standard Barr's leaks in the $5 bottle.
I had a 1991 Range Rover with a head gasket problem.
In Chicago - I had steam out the back pipe.
I put in two bottles of Barr's leaks and
by the time I got to Indiana - I had no more white steam out the back.
I got lucky.
I made it to Boston in that Rangie.
And, even then down to NY and back to Boston.
Old Apr 5, 2012 | 07:03 AM
kmyer01's Avatar
I have not wanted to use any sealants in the coolant, but at this point I am about to give in. I spent a boat load of money to change all the gaskets, I cannot do that again right now.
Old Apr 5, 2012 | 07:55 AM
re: Does not plug the radiator and heater core. And, no leaks.
Any product can clog both of these IF they are not in good shape to begin with. Be sure to reverse flush to clean out as much crud before trying stoz leakz.
Consider borrow coolant pressure tester, then you can pump up to 20 PSI, and wait for leak, makes it easier to find if engine not running.
Old Apr 5, 2012 | 09:30 AM
Do not use any Barrs leak in your engine. Send me your number and I'll call and walk you thru what to check/fix.
Old Apr 5, 2012 | 09:41 AM
ralphobell's Avatar
If you put anything in it, put this.
K-Seal - EE - Expedition Exchange Incorporated
Old Apr 5, 2012 | 12:50 PM
kmyer01's Avatar
Well all the help is awesome. Mike I will pm you here in a little while. I have a bigger problem now. I have been throwing this p1668 code. The truck will died on me while im on the highway..not good! I ordered a BCU off line, but has anyone had this problem and been able to fix it without a dealer? Closest dealer is 2 hours a way and I can only imagine the charges.
Old Apr 5, 2012 | 12:58 PM
see Fault Code P1668
Could be a wiring problem (dirty/loose connector, skint wire, etc.) Won't be cheap at the dealer.
