Coolant Leak?
Coolant Leak?
I'm starting to get high temperatures while driving short distances, just topped up the coolant about 2 days ago but and that seemed to work for a time but now it gets hot everytime I drive. It is a slow temperature rise but pretty steady. Normal operating temps around 179-183 but have been climbing up to 210. Probably would keep rising if I lived a greater distance from work. I have a Torque OBDII reader that I'm working with, which I know is pretty much just entry level and can have variance in the values it outputs.
There is definitely a leak, but short of replacing hoses and such, what is the proper course of action? Bleeding the system? Could pockets of air gotten into the system and started causing these high temps?
I'll look into the operation of the fan clutch later on today and see if it is working properly.
Need a bit of help with this one! Got a sizable trip coming.
First stop driving the truck.
The reason it is topping out @ 210 is that is when the condenser fan kicks on, in your case it is acting as an emergency fan.
Not it's intended purpose.
You need to beg, borrow or steal a coolant system pressure Tester.
We took a good look at the Disco tonight, and, using a pressure tester, we identified the water pump to have a faulty gasket. Will get to replacing that and the pump itself during the next week or so.
During the pressure tests a number of hoses were leaking very slightly. We had our PSI to 20, which is a bit high for the V8. Regardless of over-pressurizing the system, is it normal to see a miniscule amount of leakage at the hoses?
No they should not leak at . be sure to test it after the pump.
Where did you get the pressure tester? Some forum members have a difficult time finding one with an adapter that will fit the DII reservoir. Was it a loaner from one of the auto parts chains?
ZMonet
06-24-2016 04:00 PM
MyRoversNameIsCarl
08-10-2014 09:22 PM
aguison
11-18-2012 05:15 PM
lipadj46
07-08-2009 07:41 PM
