Coolant leak
Old Feb 7, 2018 | 08:34 PM
String's Avatar
5th Gear
Default Coolant leak
performing pressure test found coolant slowly coming down by timing chain into oil pan. Could this be head gasket?
Old Feb 8, 2018 | 10:54 AM
OverRover's Avatar
Can you see what side of the engine the leak is coming from?
Could be the head gasket or the front engine cover gasket itself.
Have a look just start at 2:05 > An Overview Of Land Rover Front Engine Covers
Old Feb 8, 2018 | 03:24 PM
String's Avatar
5th Gear
It's on the drivers side dripping on the oil pick up tube
watched video that was real helpful
i guess I'm taking the front cover off
just bought the vehicle the guy said he had the head gasket replaced but it overheated when he was going up hills . He said his mechanic left it idle all day and never overheated . When I drain the oil I got a little bit of antifreeze at first but wasn't a whole lot
im going to do a timing belt there's a lot of slack in it
Old Feb 8, 2018 | 03:40 PM
Dave03S's Avatar
A lot of slack in what? You don't have a timing belt, btw.
Old Feb 8, 2018 | 04:17 PM
String's Avatar
5th Gear
sorry meant timing chain
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
