coolant leak, as always the problem
Old Apr 18, 2014 | 05:59 PM
Tomzsix's Avatar
Default coolant leak, as always the problem
I'm currently leaking coolant from the bottom of the valve cover, driver side rear corner. Is it head gasket or cracked head?? I am not burning coolant, and the engine has never been hot. No check engine light, either
Old Apr 18, 2014 | 06:47 PM
Tomzsix's Avatar
could it be throttle body gasket?? inside the valve cover??
Old Apr 18, 2014 | 06:51 PM
jalodge's Avatar
Is leaving a pool on top of the valve cover?
Old Apr 18, 2014 | 07:03 PM
Tomzsix's Avatar
the leak is at the very bottom, between head and valve cover. right at the corner it drips
Old Apr 18, 2014 | 07:13 PM
Tomzsix's Avatar
OK...after snooping around, I discovered a leak from perhaps the throttle body heater tubes. It is dripping down on the front of the valve cover, and dripping off on the very corner at the rear. I thank the Gods -o- coolant that it is not a head gasket. does anyone know the shop repair for this job?? I will not work on this engine with a ten foot pole.
Old Apr 18, 2014 | 07:20 PM
dr. mordo's Avatar
It's should be pretty cheap. It's a 20 minute job. Bleeding the coolant system will take longer than replacing the gasket. So, rounding up to a full hour's labor, they'll probly charge you $100.
Old Apr 18, 2014 | 07:24 PM
Tomzsix's Avatar
Thank you very much for your advice. I can now drive my rover without "FREAKING OUT FROM SEVERE ANXIETY"
Old Apr 18, 2014 | 07:52 PM
jalodge's Avatar
Like many others including myself have done you can bypass it with a 1/4" hose mender.
ZMonet
Jun 24, 2016 04:00 PM
MyRoversNameIsCarl
Aug 10, 2014 09:22 PM
dcarsmith
Mar 8, 2007 10:16 PM
nuno106
Oct 30, 2006 03:31 PM
