Coolant leak/block
Old May 12, 2014 | 09:26 AM
haleyrover's Avatar
Default Coolant leak/block
My wife's 2004 DII (~110k) has had disappearing coolant for a couple weeks. The cause turned out to be was a blown hose from the manifold to plenum de-icer. I replaced the hose and basically it blew up like old faithful right under the throttle body gasket. I've replaced that before, but never seen a leak with this much pressure when the engine is off.
I'm thinking a new throttle body gasket, but wanted to check and see if there is anything else I should look at while I'm in there. All hose connections are solid.
humroot
Jul 22, 2019 06:33 PM
ZMonet
Jun 24, 2016 04:00 PM
bcolins
Jan 3, 2015 09:56 PM
spike29
Jul 6, 2011 03:36 PM
JBEGIN
Jun 27, 2009 12:38 PM
