coolant leak, head gaskets?
Old Nov 26, 2009 | 10:16 AM
RoverRookie's Avatar
My leak ended up being the timing cover gasket...Good Luck - RR.
Old Nov 26, 2009 | 10:50 AM
kgrab's Avatar
hey guys,
i think i found where the leak is. the picture should be pretty self explanitory. what do you guys think?
Old Nov 26, 2009 | 10:52 AM
kgrab's Avatar
btw i tried to tighten that bolt. i did get it almost a full turn tighter but it still leaks..
Old Nov 26, 2009 | 11:05 AM
lipadj46's Avatar
Do not tighten that bolt too much or your will break it off in your block. That is not where it is leaking from that is an oil pan bolt. The coolant is coming down from up higher, probably either your front engine cover or your water pump. Still could be your head gaskets. That is why you need dye and also power wash you engine so you can actually see the leak.
ZMonet
Jun 24, 2016 04:00 PM
thearmlesswonder
Jul 27, 2015 10:16 AM
Rearden Steel
May 7, 2012 08:23 PM
seamuspg
Jan 22, 2010 10:11 AM
kjordan
Oct 22, 2008 08:21 AM
