Coolant Leak, Head Gaskets and ARP Stud Questions
Old Apr 9, 2012 | 08:55 AM
Rearden Steel's Avatar
Default Coolant Leak, Head Gaskets and ARP Stud Questions
After many unsuccessful months of trying to hunt down the smell of escaping antifreeze……I now have a dripping leak. The coolant is dripping off the transmission. I still cannot find the source. I am assuming it is one of the head gaskets in back, running down the back of block, onto the transmission and then onto the ground. But before I pull the trigger on yanking the heads, any other suggestions?
Also, does anyone have the ARP stud part numbers? I looked on their website/catalog and they do not have a Land Rover kit. TIA.
Old Apr 9, 2012 | 11:07 AM
Valley pan gasket? Rent/borrow coolant pressure tester so you can hunt for leak when truck is not running. Seems like if this has been going on for months that a rear HG leak would have progressed to all out you-can't-miss-it phase.
Attached Thumbnails Coolant Leak, Head Gaskets and ARP Stud Questions-hg%2520rear%25202.jpg
Old Apr 9, 2012 | 07:39 PM
Just go pressure test the coolant system, not sure why it has taken you months to find the leak. As already mentioned, could also be the valley pan gasket caused by loose bolts.
Old Apr 9, 2012 | 07:48 PM
vandev's Avatar
Default Call mark
Call mark , he stocks theses and has correct torque settings. I got mine from him.
Chris
D&D Fabrications: Engineering & Fabrication Services
Old Apr 10, 2012 | 05:53 AM
drowssap's Avatar
Arp part number 124-2003 rover dont let them give you part number 124-2202 that is for a buick
Old Apr 10, 2012 | 07:52 AM
Higgs Boson's Avatar
Stop driving it with a leak, before it turns into more than just a leak.
Don't be scared of TTY bolts, they work very well. The studs will probably cost as much as the complete gasket set with the bolts and plenum gasket ($160+S&H).
Pull the plenum off so you can see what is going on at the back of the intake, chances are the bolts are loose and blew the valley pan gasket. You can do the valley pan and end seals (valve covers too while you are in it) for under $50 in parts. A complete head gasket set with bolts is only $150. The Bosch engine plenum gasket is another $10.
Old Apr 12, 2012 | 08:33 PM
I am not driving it. Driving the D1 whose paint job looks like something out of Mad Max. I have the kit to pressurize the cooling system. I take it up to 25 psi. It bleeds down to 22 psi over 30 minutes and then stabilizes. This is why I have not been able to find the leak. I took it for a short local drive today to get it up to temperature and when I got back it was dripping again. Same place, off the trans onto the square cross beam and onto the ground. It has never overheated. The only codes I have ever got were 0441 evap and the 0150 O2 sensor.
With almost 70K on a 4.6L D2, the possibility of it being the valley pan gasket, I am tempted to take it all the way down to the heads and do the head gaskets at the same time.........
Old Apr 12, 2012 | 08:39 PM
Always up for an excuse to invest in an inspection (snake) camera.... cheap at Harbor Freight...
Old Apr 19, 2012 | 07:15 AM
Ok....complete head gasket and bolt kit on order from AB. I will do the plugs and wires while she is apart. Any other recommendations while I have the top end off? TIA
RS
Old Apr 19, 2012 | 10:53 AM
Hay's Avatar
Hay
In addition to the plugs and wires I replaced my coil packs. Really easy when the heads are off, not so easy otherwise.
