coolant leak possible head gasket??
Old Dec 30, 2010 | 10:57 AM
samaro71's Avatar
Default coolant leak possible head gasket??
Have had a slow coolant leak for a little while now but couldn't find it. Today went home for lunch noticed temp getting warm, got out at the house and saw smoke from driver side fender well. Opened hood and the cooloant is steadily dripping onto exhaust pipe near the fire wall on the drivers side. Cant really see where it is coming from but thinking head gasket. I am pretty mechanical but have limited tools at the moment. Wondering what the cost will be and if it's something i can do myself??
Old Dec 30, 2010 | 01:53 PM
Look at the 2 small hoses under the throttle body, they are a common form of a leak.
DEo not drive the truck till it cools down and the coolant bottle is filled to the lid, then go straight to your mechanic or home and keep an eye on the temp gauge, if it moves at all, turn your heat full hot to help keep the engine from over heating.
Do not drive it but to get it fixed or you will toast your engine.
Old Dec 30, 2010 | 02:06 PM
kcabpilot's Avatar
I'm in the process of doing mine right now - similar situation but I'm leaking left side just forward of the motor mount. I did have throttle body leakage and fixed that a while back, then it started leaking where it is now, slow at first but suddenly got worse.
So far the only tools I've had to borrow were a 36mm spanner and pulley holder to get the fan off. The rest of it looks like pretty straight forward pushrod V8. Getting all of the pumps and accessories out of the way looked worse than it was, everything is mounted on two large aluminum billet brackets that come off fairly easily.
I should have it all apart this weekend. I'll post some pictures that might be helpful.
mike111
Jun 2, 2014 08:58 AM
aarongregor
Nov 7, 2011 05:47 PM
LikenDisco2k
May 3, 2009 08:25 PM
jlgolson
Nov 23, 2008 06:55 PM
elkwing
Nov 14, 2008 09:15 PM
