Is this a coolant leak tell?
Old Jan 17, 2019 | 12:56 PM
DiscoNickBK's Avatar
Default Is this a coolant leak tell?
Truck sat for 4 days. Checked oil and saw I needed to add a bit. Oil on the dipstick looked normal (little dark maybe...) Cap was stuck so the whole filler neck came unscrewed. No big deal right? Anyway once it's off I notice some light-colored stuff on the inside. Is this a sign of a HG or block crack?
I'm not overheating at all but I do have persistent gurgling in the coolant system even after multiple bleeds.
Old Jan 17, 2019 | 01:00 PM
Best4x4's Avatar
Moisture buildup/condensation = normal
Old Jan 17, 2019 | 01:09 PM
Sick, thank you. Vehicle has my paranoid. I just replaced the TBH and both hoses and I'm still smelling a bit of coolant after a drive and seeing it drop. Pressure tests held fine for 30 minutes per the last shop I took it to. Now I have a p0304 misfire and a p0134 o2 sensor code. Ugh!
Old Jan 17, 2019 | 03:40 PM
shanechevelle's Avatar
You can unscrew that fill tube.
Old Jan 17, 2019 | 03:43 PM
Yea I know the filler neck can come off, I was more worried that the light-colored residue on the inside could be from coolant getting into the oil.
Old Jan 17, 2019 | 06:03 PM
mln01's Avatar
Nope. Completely normal..
Old Jan 18, 2019 | 05:21 AM
JUKE179r's Avatar
Normal but check that your plastic PCV valve/oil separator (located on right side of valve cover) isn't clogged.
Old Jan 18, 2019 | 06:53 AM
The Deputy's Avatar
Especially normal on vehicles that get driven short distances or not very often.
Brian.
Old Jan 19, 2019 | 12:07 PM
OverRover's Avatar
Yep, normal for a LR.
Now if this was an early Porsche 944 with the internal oil cooler = BAD THINGS!
Jason Feuerstein
Mar 6, 2019 11:35 AM
User
Feb 8, 2019 02:14 PM
Mike53
Nov 17, 2018 03:40 PM
Rover De Land
Apr 5, 2013 03:02 PM
joshluseal
Mar 15, 2011 07:33 AM
