Massive coolant loss.
Old Mar 14, 2011 | 04:30 PM
joshluseal's Avatar
8th Gear
Default Massive coolant loss.
I just bought a 2000 Disco II with 127K miles. It drove fine for a week and then it started to overheat. I noticed that the coolant level was almost non-existent so I filled it back up and drove it for about 5 miles with no problems. On the way to work the next morning (after about 5 miles) I heard what sounded like rushing water hitting the firewall every time I accelerated from a stop. Needless to say, on the way home, it overheated again and there was no coolant in the reservoir. The coolant was all over the right side of the engine compartment. From the spray pattern, it appears as though it is coming from the reservoir cap. The cap was on tight so I was wondering if its possible to check if the cap is bad or if it is some other issue. I did pull the reservoir and check the hoses. No cracks and they appear to be on tight. Please help!
Old Mar 14, 2011 | 04:34 PM
goldy27's Avatar
3rd Gear
Default .
Intake gasket is the possible leak if it's hitting the firewall. I would suggest doing a pressure test.
Old Mar 14, 2011 | 04:59 PM
davidlafrance's Avatar
sounds like thermostat to me...any coolant in the oil?
Old Mar 15, 2011 | 07:33 AM
joshluseal's Avatar
8th Gear
Default Additional info
There doesn't appear to be any oil in the coolant plus the spray pattern is from the top down as the top of the fuse box is half covered with coolant but the under-hood is not affected. There is no coolant on the engine itself. It seems to stay to the left side of the engine compartment when looking at it from the front of the vehicle. Thanks for the input.
gribur
Apr 7, 2015 07:28 AM
akbarkhan
Mar 7, 2009 12:24 AM
Cessna310Guy
Nov 26, 2008 01:00 PM
Cessna310Guy
Nov 21, 2008 10:38 AM
strrvr
Freelander
Nov 19, 2008 01:20 AM
