Coolant Leak (troubleshooting help)
Old Jan 12, 2020 | 09:19 AM
scanlon's Avatar
4wd High
Default Coolant Leak (troubleshooting help)
Morning! I have been working through determining the source of a coolant leak. It is not big but consistent. I did a coolant UV light trace this morning.
Here is where I am at. I drove around for 10 minutes or so. As expected, the drips were visible in the front drive shaft area. I was able to look down from the passenger side and see the general area of the leak (I believe). Below is a picture with the UV light. Area #1 is the area of the source. It is blocked by the firewall, etc. so i could not see the true source area. It drips and forms a flow in area #2...eventually exiting in the front drive shaft area. Much gut tells me this is a compromised head gasket given the location. Any thoughts or reactions? Thank you again to everyone that has weighed in.
Old Jan 12, 2020 | 05:30 PM
Extinct's Avatar
Looks like trace #1 is above the lower exhaust manifold bolt, if that is so then it is above the head and unlikely to be a headgasket. If that is true, then the lower intake manifold gasket is leaking at the rear.
09dewaed
Mar 27, 2018 06:26 PM
robersonb
Dec 2, 2012 07:40 PM
invalidusername
Nov 20, 2012 06:23 AM
gusbone
Oct 7, 2012 09:10 AM
ewok
Feb 13, 2011 09:41 PM
